ETuning/Remote Tuning
XRT is the only Tuning company beside Cobb Tuning to demonstrate it tuning capabilities and the release of tuning information to the World before any other tuning companies. In fact, tuning companies requires Cobb Tuning to support these models. XRT don’t! Thats being innovative and creative!
Please also note XRT is a Cobb Protuner and we support tuning of the Subaru Ascent using the Cobb Accessport.
In respect to our research and development (as shown at the very below) on the Subaru Ascent & the FA24DIT operating in this vehicle, we are offering Stage 0 and 1 tuning support to owners with the following requirements:
The tuning is really considered for those not liking the small little issues as highlighted in our XRT Subaru Ascent Whatsapp group – https://chat.whatsapp.com/E1dPtXGgn3oEJAEm6P3aeU
https://xtremeracingtuning.com/2019/10/26/xrt-subaru-fa24dit-tuning/
https://xtremeracingtuning.com/2019/10/26/subaru-fa24dit-turbo-mgt22/
Facebook
https://www.facebook.com/share/p/1Emhh5zfwW/
https://www.facebook.com/share/p/1ATtofMUVa/
Videos
https://youtu.be/EoXe2WxpI-Q
https://youtu.be/zJ_G6SRK93M
https://youtu.be/oh5fojSEWUA
https://youtu.be/HhU6eCFyqMY
Research
https://www.ascentforums.com/threads/xrt-subaru-ascent-tuning-stage-1.8915/#post-120707
https://www.ascentforums.com/threads/xrt-subaru-ascent-tuning-stage-1.8915/post-120957
Customer Reviews
https://www.ascentforums.com/threads/xrt-subaru-ascent-tuning-stage-1.8915/#post-120957
https://www.facebook.com/XtremeRacingTuning/posts/1715937071877146
Stage 1 Development Tuned
Owner: RonS
Rom ID: AZ1J500V
Tyres: 225/55-17
Car Weight: 1540kg
Driver Weight: 105kg
Total Weight: 1645kg
XRT Stage 2
IHI VF52
Process West Verticooler
X-force turbo back exhaust (awaiting install)
Adjustable GFB deceptor Pro II BOV
Process West Cold Air Intake w/K&N Filter (WRX/STi 2008-14) (PWCAI04)
Grimmspeed EBCS
http://www.xtremeracingtuning.com/forum/viewtopic.php?f=140&t=810
https://www.facebook.com/XtremeRacingTuning/posts/1302594823211375
Posted by Steffen Veum on Sunday, August 26, 2018
Owner: MarekK
Rom ID: A2WC420F
Tyres: 225/55r17
Car Weight: 1500kg
Driver Weight: 82kg
Total Weight: 1582kg
Marek Kwas It been an interesting year where we have seen a good few Foresters in a modded state coming to us. Here is a…
Posted by Xtreme Racing Tuning on Thursday, July 26, 2018
XRT Stage 2
– decat uppipe
– 3″ downpipe with sports cat
– 3″ straight through exhaust with Fujitsubo RM01A muffler
– Pre97 GC8 WRX/STI TD05H-16g turbo with stock wastegate
– 550CC stock injectors, yellow, side feed
– Deatschwerks DW200 fuel pump
– STI Intercooler with Forge BOV
– Cobb 3-port boost controller
What has been checked:
– valve clearance
– compression
– new plugs (NGK ILFR6B, 0.8mm gap)
– new oil
– intake leak test
Other interesting stuff 😉
– STI hood scoop with STI air splitter
– Cusco Zero 2 suspension with pillowball mouns and camber plates
– STI calipers both front and rear, DBA T2 brake discs with CL5+ pads front, DBA Street Series with DS2500 pads rear
– Rear STI sway bar
– Titanium STI front strut bar
– Rays Gram Lights 57S 17′ wheels
