Tag Archives: subaru sti tuning
700whp+ Subaru Club – 2011 USDM STI 2.5 6MT
IAG stg 4 extreme block
14mm headstuds
Fire ring headgaskets
Pinned mains.
Garrett GTX3582R Gen 2
Ported heads, valves
Springs and Bc 280 cams
Ams intake manifold
TGV deleted
Exhaust
Full turbo back 3inch
Perrin big tube equal length headers
External wastgate 44mm
Grimmspeed 3Port boost controller
Fuel
Injector dynamics 1700x
Radium in tank dual pumper
Dual AEM 340s Fuel Pumps
Perrin fuel rails regulator
PTFE line throughout
Radium -8 feed and return lines
Radium FPR 48psi base pressure
4bar map sensor -OMNI
Gm IAT sensor
Videos – https://www.facebook.com/XtremeRacingTuning/videos/381216840855791/
MattS 600whp+ 2005 USDM STI 2.5 6MT
Matt came to me on his last hope in getting his long awaiting 2005 STI tuned, after his attempts to do it himself. I believe he did a fantastic job, but a professional hand was needed for his final push pass 25psi. Uncertain with his build (operating with issues and testing over a long period of time by him,) we offer inspiration that we can achieve results, even if it is short glory – because we can show it can be done and it was DONE!!! And in 3RD Gear. That was our achievement. In 4th gear, he is well over 600whp.
It was our first time working with the MerpMod Patch, which was nothing different to the Carberry Group N rom in a sense, but it was still interesting to see that setup outside of Cobb Tuning for a 32bit ECU Car.
I am looking forward to the future where we use the ETS FMIC and a few other minor changes like 272/280 cams.
MattS 600whp+ 2005 USDM STI 2.5 6MT @ 30psi
3rd Gear 30psi pullhttps://xtremeracingtuning.com/2020/05/04/matts-600whp-2005-usdm-sti-2-5-6mt/
Posted by Xtreme Racing Tuning on Monday, May 4, 2020
Additional postings:-
https://www.facebook.com/XtremeRacingTuning/posts/1865297076941144
https://www.facebook.com/XtremeRacingTuning/posts/1870378196433032
http://www.xtremeracingtuning.com/forum/viewtopic.php?f=110&t=914
Customer review – https://www.facebook.com/matt.slough.3/posts/10222887405802569
Below are the results and some pics of the car.
v3 3rd Gear boost - 30psi
v3 3rd Gear boost
v3 3rd Gear Dyno SAE @ 30psi
XRT v3 3rd Gear Dyno SAE @ 30psi
Merpmod Speed Density
Dual Walbro hardwired
E85 Fuel
GM IAT near throttle body
Tomioka FPR
Parallel Fuel Line w/Outfront fuel rails
1600cc FiveO Black ops inj
25i intake manifold
FMIC
3″ Perrin inlet
Blouch Dom5-XTR
OEM exh mani w/grimmspeed x-over
CNT 1.95″ Uppipe w/Tial 44mm ewg
3″ downpipe/exhaust
CA625+ head studs
Tomei Poncams
GSC +1mm valves
JE Pro-seal 1mm head gasket
EJ257
Nippon racing pistons .020 over
Nitrided crank
Manley H-tuff rods
Competition Clutch Stage 4 6-Puck
ACT Streetlite 14lb flywheel
https://www.facebook.com/XtremeRacingTuning/videos/2573005739685453/
