JacksonC - 2013 USDM Subaru STI 6MT
Posted: Sun May 27, 2018 7:00 am
Owner: JacksonC
Version: Cobb AP v3
Tyres: 245/40R18 Dunlop ZII star spec
Car Weight: 1545kg
Driver Weight: 77kg
Total Weight: 1622kg
Maximum output kW (HP)/rpm: 227 (305)/6,000 - Expected @ the wheel: 255whp
Maximum torque N·m (kgf-m, ft-lb)/rpm: 394 (40.2, 290)/4,000 - Expected @ the wheel: 240wftlb
https://www.facebook.com/XtremeRacingTu ... 9399866250
https://www.facebook.com/XtremeRacingTu ... 1260937065
Cobb AP v3
IAG stage 2 tuff shortblock - https://www.iagperformance.com/IAG-Stag ... g-1211.htm
Stock serviced heads
ID1000cc injectors
DW65c fuel pump
Cosworth fuel rail - https://www.iagperformance.com/Cosworth ... 026741.htm
Parallel routing of fuel lines
COBB Fuel Pressure Regulator
Air Pump delete
Evap delete
IAG tgv deletes
APS aluminum turbo inlet (APSWRX-CID/01)
ETS 3” intercooler
ETS 3" Intake
ATP GT3071 - http://www.atpturbo.com/mm5/merchant.mv ... y_Code=BCS
Grimmspeed EBCS
Tomei headers
HKS Bellmouth downpipe
44mm Tial external wastegate
IAG Air Oil separator - https://www.iagperformance.com/IAG-Stre ... g-7151.htm
ACT street-lite flywheel 15lbs
v2 & v18 - 4th Gear Dyno SAE
Posted: Sat Jun 02, 2018 5:43 pm
v2 4th Gear Dyno SAE.png (54.19 KiB) Viewed 16986 times
v18 4th Gear Dyno SAE.png (48.35 KiB) Viewed 16748 times
Track Preparation
Posted: Sat Jun 02, 2018 6:08 pm
Re: JacksonC - 2013 USDM Subaru STI 6MT
Posted: Fri Sep 14, 2018 5:40 am
Turbo been upgraded to an ATP GTX3582r EWG exhaust housing
Compressor Wheel: Ind: 62.5mm
Exd:82.5mm
Turbine Wheel: 68.00mm
Turbine A/R for Subaru Stock Location: .72 a/r
Compressor A/R for Subaru Stock Location: .60 a/r
https://www.atpturbo.com/mm5/merchant.m ... y_Code=SUB
v28 4th Gear Dyno SAE @ 25.5psi avg
Posted: Sun Sep 23, 2018 7:45 am
v28 4th Gear Dyno SAE @ 25.5psi.png (35.31 KiB) Viewed 16736 times
Posted: Sat Jun 15, 2019 3:10 pm
