DirkD - 2005 USDM Heavily Modified Legacy 2.5 GT 5EAT
Posted: Sat Apr 01, 2017 6:54 pm
Owner: DirkD
Rom: A2WC500C
Tyres: 225/45-17
Car Kerb Weight: 1555kg
Driver Weight: 114kg
Total Weight: 1669kg
The car was IAG Customed Tuned using a Cobb Accessport V3. This was removed and XRT is doing the full tuning.
XRT DBW-5EAT-Stg2 Tuning
IPT Clutches
IPT Torque Convertor
Hexmod Valve Body
Bulletproof Bushings
Engine
Cosworth Piston 99.75mm 8.2.1 CR Forged
Eagle H-Beam Rods Stock Length
ACL Race Main Bearings Set Standard Size Pos. 5
ACL Race Rod Bearings Standard Size 52mm
Gates Racing Timing Belt
Subaru STi 11mm Oil Pump
ARP Head Studs
Motul 5W30 8100 Series Oil
Subaru Stock Oil Filter
Cooling System
Koyo Aluminum Racing Radiator
Napa Universal Transmission Cooler
Subaru Water Pump WRX Style 2111AA026
Motul Inugel Expert Ultra Coolant
Motul MoCool
Exhaust
CoBB Up-pipe EGT Delete
CoBB 3” SS Downpipe w/Cat
MagnaFlow Cat Back Exhaust
Air/Fuel
CoBB SF Intake Air Box
CoBB Short Ram Intake System
Perrin Turbo Inlet Hose Stock
IAG AOS
IAG TGV Deletes
IAG 3mm Phenolic Spacers
Injector Dynamics ID 1000cc Top Feed Conversion w/Rails
Injector Dynamics Side Feed Conversion Feed Line Kit
DeatschWerks DW300C Series Fuel Pump Kit
Shell V-Power Nitro 93 Octane
Brakes
StopTech Sport Kit Slotted Front & Rear
StopTech SS Braided Hoses
Napa Total Eclipse Calipers Front & Rear
GrimmSpeed Master Cylinder Brace
Motul DOT 5.1 Brake Fluid
Suspension/Wheels
BC Racing BR Coilover Kit
Napa Aluminum Lower Control Arms w/Ball Joints
Enkei Tuning Raijin Gunmetal 18x8
Continental ExtremeContact DWS 06 225/40ZR18
Electronics
XRT Stage 2 ECU Engine Tuning
ProSport Halo Boost Gauge
Re: DirkD - 2005 USDM Legacy 2.5 GT 5EAT
Posted: Sat Apr 01, 2017 7:05 pm
Recommending to the customer to use Ferodo DS2500 brake pads
The customer will be using the Subaru WRX/STi Dominator 2.5XT-R "Polka Pickle" Ball Bearing Turbocharger in the near future.
Application: Subaru WRX/STi
Horsepower: 490HP
Specs
Custom low friction low inertia ceramic ball bearing CHRA
Custom high flow low inertia 60mm turbine wheel
Blouch 71mm XT compressor wheel
49lbs per min
8cm or 10cm exhaust housing available
Engine picks + Previous Tuned Dynoes
Posted: Sun Apr 02, 2017 8:38 am
IAG Tuned Quarter Mile.png (20.11 KiB) Viewed 13205 times
Videos
Posted: Wed Apr 12, 2017 10:22 pm
New 2005 Legacy GT Upgrades - 2017/04/28
Posted: Sat Apr 29, 2017 11:07 am
Engine
ARP Head Studs
IPT Rebuilt Kit w/Seals
IPT Torque Converter
HexMods Valve Body
HexMods Bulletproof Center Diff Bushings
Cooling System
ETS FMIC 3.5”
Motul MoCool
Exhaust
Perrin Equal Length Headers
CoBB 3” SS Downpipe Catless
Air/Fuel
Blouch Dominator 2.5XT-R 8cm^2
ETS Cold Air Intake
IAG                          AOS
IAG TGV Deletes
RedHorse Custom Parallel AN 6 fuel hose
Brakes
Suspension/Wheels
Tuning/Electronics
Xtreme Racing Tuning Stage 2 Engine Tune
Xtreme Racing Tuning Stage 2 Transmission Tune
ProSport Halo AFR Gauge
Turbos specs
Posted: Sat Apr 29, 2017 9:57 pm
Dominator 2.5: 60mm Turbine. 71mm compressor
Stock: 40mm turbine. 52mm compressor
