CotyJ - 2008 USDM Subaru Liberty 2.5i 5MT - Turbo Tuning
Posted: Sun Nov 22, 2015 10:20 pm
Owner: CotyJ
Rom: EZ1GB00G
Tyres:
Car Weight: 1395kg
Driver Weight: 86kg
Total Weight: 1481kg
Tomei uel header,
td06-20g
Perrin front mount
Turbo xs rfl bov
Tial 38mm ewg
3" MAF Tube
Omni 4bar
dw 65c Pump
Tech works engineering cams, springs and retainers
ID725 Injectors
3in Charles's down pipe and 3 inch exhaust all the way back.
Built EJ255(stock wrx compression) bottom end
Gates timing belt
Light crank pulley
ACT clutch, wrx flywheel,
2011 WRX transmission rear different and axles,
n/a intake manifold,
voodoo manual boost controller
Sti oil pan and baffle
Killer B oil pickup,
WRX radiator
WRX water pump,
WRX oil cooler,
WRX water crossover pipe.
Gas: 87 & 91 RON
Subaru Stage 2 SOHC Cams
Posted: Wed Jan 20, 2016 7:43 pm
Re: CotyJ - 2008 USDM Subaru Liberty 2.5i 5MT - Turbo Tuning
Posted: Fri May 13, 2016 7:12 am
Tuning has started.
Sample vid
Posted: Wed Jun 08, 2016 11:52 pm
IMG_0361.mp4
(933.95 KiB) Downloaded 4190 times
Posted: Thu Oct 13, 2016 10:15 pm
Project move on to an NA built due to wiring issues started after the turbo turbine area melt wires.
