CotyJ - 2008 USDM Subaru Liberty 2.5i 5MT - Turbo Tuning
2008+ Subaru Legacy/Outback
Owner: CotyJ
Rom: EZ1GB00G
Tyres:
Car Weight: 1395kg
Driver Weight: 86kg
Total Weight: 1481kg
Tomei uel header,
td06-20g
Perrin front mount
Turbo xs rfl bov
Tial 38mm ewg
3" MAF Tube
Omni 4bar
dw 65c Pump
Tech works engineering cams, springs and retainers
ID725 Injectors
3in Charles's down pipe and 3 inch exhaust all the way back.
Built EJ255(stock wrx compression) bottom end
Gates timing belt
Light crank pulley
ACT clutch, wrx flywheel,
2011 WRX transmission rear different and axles,
n/a intake manifold,
voodoo manual boost controller
Sti oil pan and baffle
Killer B oil pickup,
WRX radiator
WRX water pump,
WRX oil cooler,
WRX water crossover pipe.
Gas: 87 & 91 RON
Subaru Stage 2 SOHC Cams
Re: CotyJ - 2008 USDM Subaru Liberty 2.5i 5MT - Turbo Tuning
Tuning has started.
Sample vid
IMG_0361.mp4
(933.95 KiB) Downloaded 4254 times
Project move on to an NA built due to wiring issues started after the turbo turbine area melt wires.
Return to “Subaru H4 2.5i”
