ColinW - USDM 2005 Subaru Legacy Outback XT 2.5 5EAT - Tuning
Posted: Thu Mar 27, 2014 6:39 pm
Owner: ColinW
Rom: A2WC521R
Tyres:225/55-R17
Car Weight: 1576kg
Driver Weight: 91kg
Total Weight: 1667kg
Specs:- http://www.xtremeracingtuning.com/Infor ... 2.5_XT.pdf
Bore x Stroke : 99.5 mm x 79.0 mm
Displacement: 2.457 cc (150 cu. in.)
Compression ratio: 8.2:1
Valvetrain: Intake AVCS
Max. boost pressure: 13.5 psi (700 mm Hg)
Horsepower: 250 @ 6,000 rpm
Torque: 250 lb-ft. @ 3,600 rpm
5-speed automatic (5EAT)
1 - 3.540
2 - 2.264
3 - 1.471
4 - 1.000
5 - 0.834
Reverse: 2.370
Final drive ratio: 3.58 with viscous limited slip rear differential
Grimmspeed Up-pipe
Posted: Thu Mar 27, 2014 6:43 pm
Turbo
Model: IHI VF40
Compressor - 56.50mm CmpExd | 43.50mm CmpInd
Turbine: 40.00mm TrbExd | 52.50mm TrbInd
Re: ColinW - 2005 Subaru Legacy Outback XT 2.5 5EAT Tuning
Posted: Mon Mar 31, 2014 10:30 am
The Subaru OBXT shows flow restrictions and this is most likely due to the stock turbo.
Its also very interesting an engine of 8.2:1 compression and this limited. Torque and power is low. I personally would think I would have more torque for off-road performance, all control by throttle and traction control. Interesting.
Posted: Tue Apr 08, 2014 12:47 am
Update. We found some major leaks that plaques the USDM OBXT. TMIC is leaking and turbo issues. For right now we are resolving boost leak issues.
v4
Posted: Sat Apr 26, 2014 2:02 am
Perrin TMIC
OBX equal length headers
Invidia divorced wastegate catted downpipe
WRX catless uppipe
K&N reusable/cleanable panel air filter
Heat wrap on uppipe, headers, and downpipe
Stock catback
XRT Tuning - v4-Modded_vs_v1_vs_Stock.png (54.67 KiB) Viewed 26971 times
Possible Turbo Upgrades
Posted: Sat Apr 26, 2014 12:33 pm
Ok. Here are my thoughts after working with "InTheBay" log reviews and general overview of the performance of the XT in a detail manner. That is looking at the boost response, Engine VE, Fuel, Ignition, etc and thinking of a possible turbo upgrade for the XT using either Blouch or BNR
Based on the internet feedback on the XT, I can safely assume "InTheBay" OBXT is no different to any other XT out there. Per usual, there is a lack of visual data on this and thanks to when I first started out Tuning, sites like Edge Tuning did just that.
If you look at the spec on the XT (Xtreme Racing Tuning ? View topic - ColinW - 2005 Subaru Legacy Outback XT 2.5 5EAT Tuning), I personally find it interesting the engine compression is low, but this could be due to "pissed" poor gas it may see around the world. Who knows. Compression is on par with STI's etc.
The turbo specs as noted on the internet and as show here (Xtreme Racing Tuning ? View topic - ColinW - 2005 Subaru Legacy Outback XT 2.5 5EAT Tuning), one can say it could be equivalent to the Garret GT2056:
Turbo PR.png (2.36 KiB) Viewed 26966 times
That being said from tuning, I hit a hard limit of 28+ lb/min engine flow. I could reach 30, but it doesn't make sense since the stock engine flows 26 and going to 28, I am see some pinging. So that tells me although there are mods like a bigger Perrin TMIC, new headers and full turbo-back exhaust system, there is a limit.
The Blouch GT 380XT and the 440XT are nice turbos. There produce 380chp and 440chp consecutively. One fantastic design is the 68mm Extruder billet compression wheel.
The BNR turbo hybrids looks like a nice setup and economical. There do not carry billet wheels, except for the FP 68HTA compression wheel. Based on cost and performance, the BNR/HTA 68-TD05H offers the best of both worlds. Quicker spool, nice midrange and good top end due to the TD05H.
Steamspeed STX-67 OBXT Turbo
Posted: Sat May 10, 2014 9:10 pm
We are looking at the Steamspeed Garrett GTX style compressor wheel on a Kamak based CHRA and Kamak STS 9-blade Inconel 718 Turbine wheel.
http://www.xtremeracingtuning.com/forum ... ?f=4&t=513
New mods
Posted: Fri Nov 14, 2014 9:33 pm
DW 850CC injectors
DW fuel pump
TGV Delete
BNR 18G turbo
Phenolic TGV spacers
Re: ColinW - 2005 Subaru Legacy Outback XT 2.5 5EAT - Tuning
Posted: Mon Nov 17, 2014 6:48 am
