Injector Dynamics (ID) Data for Tuning
Posted: Wed Jun 27, 2012 7:11 pm
ID1000 - Nominal Flow Rate - 1015cc/min @ 3 bar (43.5 psi)
Posted: Wed Jun 27, 2012 7:12 pm
Basic Specifications:
- Nominal Flow Rate - 1015cc/min @ 3.0 Bar (43.5 psi) Using Gasoline at 52 Degrees C (125 Degrees F)
Maximum Differential Fuel Pressure - 7.0 Bar (101.5 psi)
Fuel Compatibility - Compatible With All Known Fuels
Electrical Connector - USCAR
Subaru ECU Injector Latencies Settings:
- (v),(ms)
6.50,3.608,
9.00,1.928,
11.50,1.304,
14.00,0.992,
16.50,0.760
ID725 - Nominal Flow Rate - 715cc/min @ 3 bar (43.5 psi)
Posted: Sun Aug 05, 2012 10:39 am
- Nominal Flow Rate - 715cc/min @ 3.00 Bar (43.5 psi) Using Gasoline at 52 Degrees C (125 Degrees F)
Maximum Differential Fuel Pressure - 8.5 Bar (123.5 psi)
- (V),(ms)
6.50,2.488,
9.00,1.524,
11.50,1.104,
14.00,0.792,
16.50,0.640
ID850 - Nominal Flow Rate - 885cc/min @ 3 bar (43.5 psi)
Posted: Sun Aug 05, 2012 10:56 am
- Nominal Flow Rate - 885cc/min @ 3.0 Bar (43.5 psi) Using Gasoline at 52 Degrees C (125 Degrees F)
- (V),(ms)
6.50,2.848,
9.00,1.760,
11.50,1.204,
14.00,0.912,
16.50,0.684
ID2000 - Nominal Flow Rate - 2225cc/min @ 3 bar (43.5 psi)
Posted: Sun Aug 05, 2012 11:57 am
- Nominal Flow Rate - 2225cc/min @ 3.00 Bar (43.5 psi) Using Gasoline at 52 Degrees C (125 Degrees F)
Maximum Differential Fuel Pressure - 9.0 Bar (130.5 psi)
Fuel Compatibility - Compatible with Methanol/Ethanol/All Known Hydrocarbon Fuels. Incompatible with MTBE/Nitro Methane/Nitro Propane.
Electrical Connector - Denso
- (V),(ms)
6.50,1.988,
9.00,1.100,
11.50,0.724,
14.00,0.496,
16.50,0.344,
