Basic Specifications:
- Nominal Flow Rate - 1015cc/min @ 3.0 Bar (43.5 psi) Using Gasoline at 52 Degrees C (125 Degrees F)
Maximum Differential Fuel Pressure - 7.0 Bar (101.5 psi)
Fuel Compatibility - Compatible With All Known Fuels
Electrical Connector - USCAR
Subaru ECU Injector Latencies Settings:
- (v),(ms)
6.50,3.608,
9.00,1.928,
11.50,1.304,
14.00,0.992,
16.50,0.760
