Professor - 2006 JDM Subaru STI Spec C
2001+ Subaru STI
Owner: Professor
Tyres: 225/45-17
Total Weight: 1575kg
2006 STI Spec engine swapped into a 2004 STI Spec
FMIC
AVO Wastegate - 15psi set
Blitz Boost Controller
Perrin Intake
Full Turbo-back 3" Exhaust system
Combine 4th Gear Runs.png (19.68 KiB) Viewed 15365 times
3rd Gear Dyno - Mix gas.png (17.36 KiB) Viewed 15365 times
2006 JDM Subaru STI Spec C - XRT-Tuned R-0
R version 0 @ 18.5psi
3rd Gear Dynoes combine - 18.5psi.png (18.45 KiB) Viewed 15354 times
2006 JDM Subaru STI Spec C - XRT-Tuned R-1
R-1 Results
R-1 3rd Gear Dyno 18.5psi.png (16.74 KiB) Viewed 15353 times
Professor - 2006 JDM Subaru STI Spec C w/ Blouch Dom 1.5TS
http://www.xtremeracingtuning.com/forum ... =110&t=419
New Mods
  • ID1000 Injectors
  • Subaru WRX/STi Dominator 1.5XT-R Twinscroll Turbocharger
Application: Subaru WRX/STi JDM Twin Scroll Turbocharger
Horsepower: 470HP
Specs
  • Garrett Ball bearing CHRA
  • 56.5mm Turbine Wheel
  • 71mm XT Compressor wheel
  • 47lbs per min
  • BPT Twin Scroll Turbine housing
Target AFR = 11.98
IAT = 68C to 50C
Inj Max. Duty = approx. 60%
Subject: RE: Speed Density
Date: Sun, 27 Apr 2014 12:27:48 +0000
To: Xtreme Racing Tuning
Hi Edward, as usual, you rose to the challenge, thanks for your quick response to my request for tuning my car with the new TMIC etc. While we have not completed the tuning, the car is purring, running smoothly, no bucking. Even at low boost, the response is quite good. I can't wait to do the other minor changes and complete the tuning. I am once more a happy camper, and I am thinking of maybe running D & W on may 25th. Both the Car and Driver feel revitalized. Lol.
