3" catless turboback
k&n filter
Aquamist 2D water injection system (100% water injection only)
Prodrive 3-port solenoid (will install)
My VF36 has been ported and polished
IC spray has the auto function, all working properly
Walbro 255Lb/Hr
JDM Impreza WRX STi Spec C MY05
TY856WB6JA
3.636 2.375 1.761 1.346 1.062 0.842 3.545 1.000
3.900
DCCD (35:65)
Helical LSD
Hyper GC8 JDM Spec C RA V9 - Russia Tuned
Re: Hyper GC8 JDM Spec C RA V9 - Russia Tuned
Below is the power to the wheel in the light GC8 body.
- Attachments
- Stg2-4 4th Gear Dyno #2 @ IAT=23-17C
- stg2-4 4th gear Dyno #2.png (11.58 KiB) Viewed 8810 times
- Stg2-4 4th Gear Dyno #1 @ IAT=29-19C
- stg2-4 4th gear Dyno.png (12.2 KiB) Viewed 8810 times
West_Minist
Subaru Expert Tuner
info@xtremeracingtuning.com
Viciously Tuned, Driven Hard
Subaru Expert Tuner
At present, the Water injection is faulty and sent for repairs. Noting that, the follow dyno is on the same car, but without water intection. All on the stock ECU, 21psi Wastegate and detuned to run at 22psi.
- Attachments
- S2-23 Dyno
- s2-23+.png (11.17 KiB) Viewed 8808 times
