2005 ADM Subaru Liberty 3.0R Spec B 6MT - Tuning Process
Owner: BlackFlatSix05
Rom: D2WD603H
Car Weight: 1470kg
Driver Weight: 98kg
Total Weight: 1568kg
The fuel injected flat 6-cylinder engine has a 3.0-litre (3000cc) capacity and both cylinder heads and the engine block are made from aluminium alloys. Chain-driven dual overhead camshafts per cylinder bank actuate 4-valves per cylinder, complete with and variable valve timing (VVT) and lift. A compression ratio of 10.7:1 allows 95 octane petrol to be used, which fills a 64 litre fuel tank.
Max Power: 180kW @ 6600rpm
Max Torque: 297Nm @ 4200rpm
Wheel power is normal 50units less in Subaru drivetrains. That implies 130kw and 247Nm @ the wheels
Gear Ratio's
3.635
2.375
1.761
1.346
0.971
0.755
Final: 3.9
HKS Panel Filter
Hitech quad tip Exhaust Mufflers
Re: 2005 ADM Subaru Liberty 3.0R MT
Stock Landbase Dyno
My05 ADM 3R - Stock.png (97.55 KiB) Viewed 24733 times
Software Dyno
Stock 3rd Gear Dyno #1 20090617.jpg (282.27 KiB) Viewed 24784 times
Based on rpm
Stock 3rd Gear Dyno-s #1 20090617.jpg (278.79 KiB) Viewed 24784 times
Based on speed
BlackFlatSix05
Re: 2005 ADM Subaru Liberty 3.0R Spec B 6MT
Post by BlackFlatSix05 »
That would be my car. :D
BlackFlatSix05
Re: 2005 ADM Subaru Liberty 3.0R Spec B 6MT - Tuning Process
Only picture I have of the air filter is this one. :D
Stock driving performance
Stock Driving Performance.png (23.74 KiB) Viewed 24734 times
Stock Performance - FLKC-FKC.jpg (299.47 KiB) Viewed 24760 times
Stock Dyno First Gear
Stock 1st Gear Dyno - r.jpg (307.39 KiB) Viewed 24760 times
Second Gear Dyno
Second Gear Dyno
Stock 2nd Gear Dyno - r.jpg (245.66 KiB) Viewed 24760 times
Stock 3rd gear Dynos Combine
Stock 3rd Gear Dyno-r combine.jpg (264.28 KiB) Viewed 24760 times
Stock Gear Dyno-r - 3rd vs 2nd: Higher values represent 3rd Gear
Stock Gear Dyno-r - 3rd vs 2nd.jpg (257.36 KiB) Viewed 24760 times
Stock 4th Gear Dyno Stats
Stock 4th Gear Dyno-r - EL vs FLKC vs FKC.jpg (324.14 KiB) Viewed 24760 times
Stock 4th Gear Dyno-r.jpg (322.81 KiB) Viewed 24760 times
I would advice you to shift around 6500+rpm in the future
