Subaru Legacy Twin Turbo - 2001 - 2002
Kosti - ADM Legacy 2002 Twin Turbo Auto
PT1-1 - Very first gas tuned and move boost from 1.81psi to 1.88psi Abs
R1 Road Boost
Boost
Boost
R1 Road Software Dyno @ Smoothing Factor = 14
Boost peak to 21psi
Boost peak to 21psi
stg2-5-road-power-7k @ sm=14.png (10.25 KiB) Viewed 35422 times
R1 Road Software Dyno @ Smoothing Factor = 17
Boost peak to 21psi
Boost peak to 21psi
stg2-5-road-power-7k @ sm=17.png (10.05 KiB) Viewed 35426 times
2002 JDM Subaru Legacy Twin-Turbo - Auto
The Dyno below was part of the tuning series for the Auto TT.
Boost till the redline was less than 13.5psi from 5000rpm.
Around the same power as a WRX, but slightly more, it dusts off 180kph like nothing, even faster than the wrx.
2003 JDM Subaru Legacy Twin Turbo Auto - BB
Untuned
HKS Carbon Ti exhaust
Fully stock car
Tuning Level = None
Stock Exhaust system Performance Dyno - 2nd gear.png (11.38 KiB) Viewed 36772 times
Re: 2003 Subaru Legacy Twin Turbo Auto - Stock
Untuned
Same car with SYMS downpipes, replacing the stock downpipe with cats.
The SYMS piping is bigger
Syms DP Performance Dyno - 2nd gear.png (12.34 KiB) Viewed 36762 times
The next mod is going to remove the stock resonator. The car is very quiet.
After the AVO TMIC goes in, it will be tuned.
Hyper
Post by Hyper »
nice downpipes!
never seen those before for twin scrolls...
will the car be catless?
THe car is catless. Those are the flex pipes. I made sure I posted the correct dp's.
I cannot wait to log it after the massive silencer computer control device comes out.
Untuned
Red - Stock DP's
Blue - SYMS DP's
16.5 is a spike. Boost setting is 13+psi. Thats why is comes down pretty sharply.
Syms DP vs stock DP - Performance Dyno - 2nd gear.png (10.54 KiB) Viewed 36712 times
ADM Legacy 2001 Twin Turbo - Manual - Semi R-Tuned
XRT R-Tuned 3rd Gear Dyno IAT=17C.png (24.65 KiB) Viewed 35155 times
Full Race Rom results below for 4th Gear
XRT R-Tuned 4th Gear IAT=14C.png (22.95 KiB) Viewed 35162 times
Re: 2003 JDM Subaru Legacy Twin Turbo Auto - BB
5MT conversation, including additional exhaust mods
Stock 5MT conversion 3rd gear Boost 20090416 - IAM=9 IAT=37C.png (16.35 KiB) Viewed 36650 times
Stock 5MT conversion 3rd gear Dyno 20090416 - IAM=9 IAT=37C.png (13.39 KiB) Viewed 36652 times
Updated Dyno comparisons.png (16.51 KiB) Viewed 36653 times
Return to “Legacy/Outback”
