Raptor - 2011 Subaru XV 6MT - Tuning
2010+ Subaru CVT 2.5i
Subaru Impreza FB/FA
Subaru Crosstrek
Subaru XV
Owner: Tim - Raptor
Rom: EP5I010q
Tyres: 225/55-17
Car Weight: 1430kg
Driver Weight: 72kg
Total Weight: 1502kg
Engine
Valvetrain: Dual AVCS
Max. output @ Crank (DIN)(kW(PS)/rpm): 110 (150)/6,200rpm
Max. torque @ Crank (DIN)(Nm(kgfm)/rpm): 196 (20.0)/4,200rpm
6MT based on the 5MT
1 - 3.545
2 - 1.888
3 - 1.296
4 - 0.972
5 - 0.780
6 - 0.695
Final drive ratio: 4.444
Dyno'es performed against rpm
v0 vs Another Tuner Based Map - 2nd Gear Dyno SAE vss
Customer reviews:
Going for quick general drive just to get more feel.
Seems very torquey, power is best ever, revs out clean, idle is good and run down fine.
Motor doesn't seem stressed at all.
At idle I can here the motor but cannot feel it - smooth as glass
Lot of torque around 2000 - 2400rpm, feels better and barks a lot more out the exhaust
XRT Curve - Red/Blue
v0 vs Kido - 2nd Gear Dyno SAE vss.png (21.62 KiB) Viewed 15820 times
v2 Comments
I loaded your V2 and went around the block - compared to the original tune it's SO much more torquey
v2a w/ Massive Exhaust AVCS tuning
No tuning yet in the high rpm.
The AVCS tune did feel very meaty with torque but it's hard to know the size of gain - felt good
The V2 and V2A really have great low and mid with nice over rev at the top
SC Tuning
High Flow Exhaust, 2.5"
Supercircuit Headers
High Flow CAT
SCv7 - 3rd Gear ACT.png (11.61 KiB) Viewed 15146 times
SCv7 - 3rd Gear Boost.png (11.45 KiB) Viewed 15146 times
SCv7 vs v0 - 3rd Gear Dyno SAE.png (59.83 KiB) Viewed 15146 times
