Tag Archives: West_Minist
RonS – 2011 ADM Subaru Forester S-edition 5EAT
Owner: RonS
Rom ID: AZ1J500V
Tyres: 225/55-17
Car Weight: 1540kg
Driver Weight: 105kg
Total Weight: 1645kg
XRT Stage 2
IHI VF52
Process West Verticooler
X-force turbo back exhaust (awaiting install)
Adjustable GFB deceptor Pro II BOV
Process West Cold Air Intake w/K&N Filter (WRX/STi 2008-14) (PWCAI04)
Grimmspeed EBCS
http://www.xtremeracingtuning.com/forum/viewtopic.php?f=140&t=810
https://www.facebook.com/XtremeRacingTuning/posts/1302594823211375
SteffenV – Cobb Remote Tuning 2007 USDM Subaru 2.5 OBXT 5MT
Posted by Steffen Veum on Sunday, August 26, 2018
MarekK – 2004 EDM Forester 2.5XT 5MT
Owner: MarekK
Rom ID: A2WC420F
Tyres: 225/55r17
Car Weight: 1500kg
Driver Weight: 82kg
Total Weight: 1582kg
Marek Kwas It been an interesting year where we have seen a good few Foresters in a modded state coming to us. Here is a…
Posted by Xtreme Racing Tuning on Thursday, July 26, 2018
XRT Stage 2
– decat uppipe
– 3″ downpipe with sports cat
– 3″ straight through exhaust with Fujitsubo RM01A muffler
– Pre97 GC8 WRX/STI TD05H-16g turbo with stock wastegate
– 550CC stock injectors, yellow, side feed
– Deatschwerks DW200 fuel pump
– STI Intercooler with Forge BOV
– Cobb 3-port boost controller
What has been checked:
– valve clearance
– compression
– new plugs (NGK ILFR6B, 0.8mm gap)
– new oil
– intake leak test
Other interesting stuff 😉
– STI hood scoop with STI air splitter
– Cusco Zero 2 suspension with pillowball mouns and camber plates
– STI calipers both front and rear, DBA T2 brake discs with CL5+ pads front, DBA Street Series with DS2500 pads rear
– Rear STI sway bar
– Titanium STI front strut bar
– Rays Gram Lights 57S 17′ wheels
StephenC 2008 USDM Subaru Legacy LGT 2.5 5EAT Tuned for Response
Cobb AP Stg2 replaced by XRT ECU Stage 2 Tuning
XRT 5EAT Tuning
Tomei Equal length header, Tomei Up-pipe
VF52 turbo, mild porting of exhaust
Grimmspeed EBCS
Turbosmart compact recirculating BPV (not a mod really but…)
Cobb Catted DP, stock mid, STI mufflers
AVO TMIC
Stock airbox and air filter
Reviews:-
Cobb AP Pro Tune & XRT: The Differences
http://www.xtremeracingtuning.com/forum/viewtopic.php?f=115&t=770#p2391
OK we are close this one was good!
Town driving–Throttle response is still nice and strong-nothing changed there and that is good. A little jumpy in S# at ~25% throttle around 3K in 2nd and 3rd BUT** it’s very responsive to input and i don’t have the most steady foot on bumpy roads:-) doesn’t do it in S mode so yeah…my foot lol!
3rd gear pull– Only 1 single instance (single cell) of ping (-1.5) right before peak boost. a few -1.5 cells as I lifted off throttle at 6000rpm. Feels Strong.
How it feels on the 3rd gear pull–pulls harder as the boost spools up–perfect!. It feels like it hits a shot of Nitrous about 4600RPM as it transitions from 8.5degrees to 10.5degrees of timing. It’s subtle, not a surge, but I thought I’d point that out.
Roll on acceleration about 3000rpm—amazing in all gears. I don’t really feel that transition in this circumstance.
2nd gear is just nuts. I never really tried it before at WOT. SO yeah, nice one!
Shifting–under load, nice and sharp and quick. I don’t know if it’s possible to tune this—-> but it would be nice for the trans to respond faster to paddle inputs, especially at light load around town. No big deal though;-)
Alright, well where do I start? As we are getting close to the end of the tuning process I’m thoroughly impressed. Ed’s knowledge and feedback to my queries has been fantastic. He’s quick to respond and I challenge any tuner to provide such good customer support! Feedback is nearly immediate and revisions come daily (sometimes more often!).
I urge any Cobb tuned customer to consider XRT. If you have an 5EAT or if you are Cobb tuned on Canadian petrol, you need to contact XRT tomorrow!!
My Cobb stage 2 provided predictable, modest power improvements as advertised from Cobb. However, as predicted, the pinging (feedback knock, fine knock learning) was endemic, over all grades of petrol. Only after a couple revisions he had the power far above Cobb’s tune, and a transmission that provides strong, fast shifts. We are onto Rev 5, and the power keeps building and I’m getting zero pinging under all conditions, on standard Canadian 91 petrol! And the shifting and throttle response are unreal. Night and day over an Off The Shelf tune…. BRAVO Edward!!!!
Turbocharged Tuning – 2017 USDM Subaru Crosstrek/XV/Impreza CVT
Reviews:-
http://www.xtremeracingtuning.com/forum/viewtopic.php?f=123&t=796#p2480
By the way The AVO turbo kit and the raptor supercharger kits are not available for the 2015+, due to no tuning or fuel pump solutions
Thanks to XRT Ed, I have been given the confidence to move forward with the project. I live by multiple Subaru tuners, and was turned down by all of them. Ed said he was up to the challenge, and I like working with people that have a can do attitude
http://www.xtremeracingtuning.com/forum/viewtopic.php?f=123&t=796&start=10#p2493
Now the car is running great. I have made some decent pulls to collect data for ED. He is doing an outstanding job!!! This is the first time anyone has tuned a 15+ NA for turbo and there are a lot of hurdles to overcome. ED is knocking it out of the park. Every time he sends me a ROM it gets better and better. His CVT tune is awesome, makes it feel like a sports car not a grocery getter.
Modifications
XRT XV/Crosstrek/Impreza Tuning
XRT NA-Turbo Tuning
XRT CVT Tuning
Full Mod list – http://www.xtremeracingtuning.com/forum/viewtopic.php?f=123&t=796
XV-T (WRXV) Tuned by Xtreme Racing Tuning (XRT)WRXVThis morning we release our very first tune (calibration) for the…
Posted by Xtreme Racing Tuning on Tuesday, April 24, 2018
Bartosz Rotrex Supercharged 2004 EDM H6 3.0 5EAT Outback
  • Rotrex C38-81
  • 65mm Pulley
  • Stock MAF mounted in 76mm pipe before SC
  • 550x230x65mm Intercooler: http://fmic.pl/jednostronne/279-interco … x65mm.html
  • Cone filter
  • Supertech 8.5:1 Pistons
  • 76mm piping before SC, 63mm after (incl. IC)
  • MAP mounted in stock place in intake manifold
  • OEM Subaru Dump Valve (from Forester turbo), return pipe goes into pipe just before SC but after
  • MAF
  • Deatschwerks DW200 fuel pump
  • STI Pink injectors
PaulH – 2011 JDM Subaru Impreza WRX STI A-Line 2.5 5EAT
Reviews:-
Car feels amazing during pulls and can’t wait to get it on a nice stretch of road
The car is now feeling much better than I imagine, it moves and feels GREAT threw out the entire power-band, no more waiting till after 5000rpms to feel being pushed back in the seat. XRT is the best in customer service, turn around time and great advisor and tuner. Turn the car from slouchy to speedy
Modifications
XRT Stage 2
XRT 5EAT Tuning
Zero Sports intake
Decatted downpipe
Zero Sports exhaust
Zero Sports pulley kit
Grimspeed EBC
Turbo Heat shield and blanket
Blouch 20G XTR (8cm) (47lb/min|480CHP)
ID 1050X
DW Fuel pump
TGV Deletes
Videos
RooseveltC – 2011 JDM Subaru WRX STI tS (aka Spec C) 2.0 6MT
Rom:AZ1G800T
Tyres: 245/40-18
Car Weight: 1477kg
Driver Weight: 104kg
Total Weight: 1581kg
2011 JDM Subaru WRX STI Type S (aka Spec C) 2.0 6MTThe car felt pretty good on the road and the chassis for this…
Posted by Xtreme Racing Tuning on Sunday, January 28, 2018
With further tuning and running at drags, please see the times below:
FHartell – 2016 Subaru Crosstrek FB20 CVT
Modifications:
  • XRT Tuning
  • CVT Tuning
  • XRT Torque Management Patch (XTMP)
  • Infernofab UEL FB20 Exhaust Headers
  • HPS Short Ram Intake
  • Cherry Bomb Glass Pack 87521CB Muffler
Initial Reviews
http://www.subaruxvforum.com/forum/engi … ost1742313
Well I’m going with XRT as far as the tuning goes. His customer support and reviews of his tunes are very good.
http://www.subaruxvforum.com/forum/engi … ost1754113
XRT has you logging constantly to give you a custom tune for whatever mods you might have installed. Is it a little pricey. Yes but the product along with his customer support is AWESOME!
http://www.subaruxvforum.com/forum/engi … ost1758129
http://www.subaruxvforum.com/forum/engi … ost1758153
Just a little update on the tuning I’m receiving from XRT.
As of now I installed the updated ROM he sent me (haven’t driven it yet) but I can say that the prior one was AWESOME! Small issues from when I open it up from a stand still but when I need passing power it’s there!
Tranny behavior is near perfect! And besides all of this he’s their with better than excellent customer support!
http://www.subaruxvforum.com/forum/engi … ost1761042
Ed, all I can say is WOW! This latest tune v0c3 is by far the best you’ve done! Great power off the line & great power for passing. The rpm’s while cruising 70 or 75mph are great for mpg!
I’m not looking for WRX power btw. I want the best of both for the motor I have and it’s almost there! GREAT JOB!
With the current mods and now fuel review, the car is running very lean.
Lean condition due to header and Intake with no tuning
http://www.subaruxvforum.com/forum/engi … ost1766138
Fellow Trekkers. I’m not here to bash anyone but I have to say that Xtreme Racing Tuning is AWESOME! Since I’ve been working with them I’ve logged a bunch had a bunch of new ROMS (tunes) sent to me and their customer support is by far the BEST! These are not one off tunes. They are dialed in to how you drive!
