Logging
Posted: Thu Dec 24, 2020 10:10 pm
AF Correction 1 (%)
AF Learning 1 A1 (%)
AF Sens 1 Ratio (AFR)
AVCS Exh Right ()
AVCS In Left ()
Accel Position (%)
Calculated Load (grev)
Coolant Temp (F)
Dyn Adv Mult (DAM)
Dynamic Adv ()
Feedback Knock ()
Fine Knock Learn ()
Fuel Inj FP Mult Table (ms)
Gear Position (Gear)
Ignition Timing ()
Inj Duty Cycle (%)
Intake Temp (F)
Intake Temp Manifold (F)
KS Noise Cyl 1 (raw)
KS Noise Cyl 2 (raw)
KS Noise Cyl 3 (raw)
KS Noise Cyl 4 (raw)
KS Thresh Cyl 1 (raw)
KS Thresh Cyl 2 (raw)
KS Thresh Cyl 3 (raw)
KS Thresh Cyl 4 (raw)
MAF Volt (V)
Man Abs Press (psi)
Primary Ign ()
Primary Ign Table ()
RPM (RPM)
Throttle Pos (%)
Vehicle Speed (mph)
Wastegate Duty (%)
AVCS Exh Right ()
AVCS In Left ()
Accel Position (%)
Coolant Temp (F)
Dyn Adv Mult (DAM)
Dynamic Adv ()
Feedback Knock ()
Fine Knock Learn ()
Ignition Timing ()
Inj Duty Cycle (%)
Intake Temp (F)
MAF Volt (V)
Man Abs Press (psi)
Primary Ign ()
RPM (RPM)
Throttle Pos (%)
Vehicle Speed (mph)
Wastegate Duty (%)
