MattS - 2005 USDM STI Merp Tuning
Posted: Sat Apr 18, 2020 3:15 pm
Owner: MattS
Rom: A2ZJ710J
Tyres: 245/45r17
Car Weight: 1480kg
Driver Weight: 150kg
Total Weight: 1630kg
https://www.facebook.com/XtremeRacingTu ... 7076941144
Merpmod Speed Density
Dual Walbro hardwired
E85
GM IAT near throttle body
Tomioka FPR
Parallel Fuel Line w/Outfront fuel rails
1600cc FiveO Black ops inj
25i intake manifold
FMIC
3" Perrin inlet
Blouch Dom5-XTR
OEM exh mani w/grimmspeed x-over
CNT 1.95" Uppipe w/Tial 44mm ewg
3" downpipe/exhaust
CA625+ head studs
Tomei Poncams
GSC +1mm valves
JE Pro-seal 1mm head gasket
EJ257
Nippon racing pistons .020 over
Nitrided crank
Manley H-tuff rods
Competition Clutch Stage 4 6-Puck
ACT Streetlite 14lb flywheel
Pre-XRT tuned @25psi
Posted: Sun Apr 19, 2020 4:37 am
v3 3rd Gear Dyno SAE
Posted: Mon May 04, 2020 1:13 pm
v3 3rd Gear boost - 30psi.png (15.15 KiB) Viewed 13951 times
v3 3rd Gear Dyno SAE @ 30psi.png (33.04 KiB) Viewed 13951 times
Customer's review
Posted: Mon May 04, 2020 3:49 pm
https://www.facebook.com/matt.slough.3/ ... 7405802569
Over time I've learned to tune to small degree. But I wanted to turn things up a notch and XRT has the tools, knowledge, and experience to do just that. Ed smoothed things out and the tune worked out better than hoped.... and even if he doesn't agree with your choice in parts Ed will make it work for you and/or recommend the best options for your wants and needs. If you are too far from a dyno or hate long waiting lists, or just want a good tune I wouldn't hesitate to reach out to XRT
