Accel. Opening Angle (%)
AF Sensor #1
Air Flow Sensor Voltage_ (V)
Ambient Temperature (BC)
Calculated Engine Load (g/s
Coolant Temp. (BC)
Engine Speed_ (rpm)
Ignition timing adv. #1 (B)
Knocking Correction (deg)
Intake Air Temp. (BC)
Learned Ignition Timing_ (deg)
Long term fuel trim B1 (%)
Mani. Relative Pressure (PSI)
Mass Air Flow_ (gs)
Mani. Absolute Pressure (PSI)
Oil Temperature (BC)
Relative Throttle Pos. (%)
Short term fuel trim B1 (%)
VVT Adv. Ang. Amount R (deg)
VVT Adv. Ang. Amount L (deg)
VVT Exh. Retard Ang. R (deg)
VVT Exh. Retard Ang. L (deg)
Vehicle Speed_ (kph)
Logging: 2015+ SubaruEdit 2.0/2.5i Impreza/XV/Legacy
