PedroF - 2005 USDM Outback XT w/ JDM 2.0 Motor JDM 5MT
Posted: Mon Nov 25, 2019 10:38 pm
Owner: PedroF
Rom:
Tyres: 225/60R17
Driver Weight: 127kg
Total Weight: 1692kg
https://www.subaruoutback.org/threads/0 ... ld.516068/
XRT Stg2
XRT 5EAT
2005 Jdm ej20y Motor w/ twinscroll - stock tgv delete - stack exhaust avcs
Ej20y jdm ecu
Stock ecu tune for inspection
Fresh timing belt
Valve cover gasket
New accessory belts
New spark plug and coils
Killerb baffle
Moroso oil pickup
Updated oil pan, new gasket
H6 oil filter
Jdm 5mt
Sachs clutch kit
3" turbo back high flow cat exhaust
Custom wrapped downpipe
Front mount intercooler
Bypass valve
Fujimoto oil valve
iWire avcs wiring harness
Snorkel with in-line air filter
Air-oil seperator
Mishimoto radiator
Boost Guage in cubby hole
Oil temp and pressure Guage in cubby hole
Lc-2 with air-fuel ratio Guage in glove box
Owner: PedroF
Rom:
Tyres: 225/60R17
XRT Stg2
XRT 5EAT
Ej20y jdm ecu
Fresh timing belt
Valve cover gasket
New accessory belts
Killerb baffle
Moroso oil pickup
H6 oil filter
Jdm 5mt
Sachs clutch kit
Bypass valve
Fujimoto oil valve
Air-oil seperator
Mishimoto radiator
