Logging
Posted: Wed Aug 01, 2018 3:46 pm
https://cobbtuning.zendesk.com/hc/en-us ... to-Datalog
Gauges setup - https://cobbtuning.zendesk.com/hc/en-us ... yed-Gauges
Accelerator Position
A/F Correction #1
A/F Learning #1
A/F Sensor #1 (AFR)
Battery Voltage (V)
Coolant Temperature (C)
Calculated Load
Engine Speed (rpm)
Feedback Knock Correction
Fine Learning Knock Correction
Gear Position (Gear)
Dynamic Advance Learning
Dynamic Advance Multiplier
Ignition Timimg
Injector Duty Cycle (%)
Intake Temp (C)
Intake Temp Manifold
AVCS Exhaust Left
AVCS Exhaust Right
AVCS Intake Left
AVCS Intake Right
Knock Correction Advance (degrees)
Manifold Relative Pressure
Mass Airflow (corrected)
Mass Airflow Voltage
Oil Temperature (C)
Wastegate Duty
Vehicle Speed (kph)
Throttle Position
A/F Correction #1
A/F Learning #1
A/F Sensor #1 (AFR)
Battery Voltage (V)
Calculated Load
Engine Speed (rpm)
Ignition Timimg
Intake Temp (C)
AVCS Exhaust Left
AVCS Exhaust Right
AVCS Intake Left
AVCS Intake Right
Oil Temperature (C)
Wastegate Duty
Vehicle Speed (kph)
Throttle Position
