KeithC - 2009 USDM Subaru OBXT 2.5 5EAT
Posted: Sun Apr 29, 2018 2:22 pm
Owner: KeithC
Rom: A2TB002C
Tyres: 235/45-18
Car Kerb Weight: 1635kg
Driver Weight: 90kg
Total Weight: 1725kg
XRT ECU Stage 3
XRT 5EAT Tuning
Stock location GT3076R CHRA , Mambatek compressor (3" inlet) and exhaust housings (.63)
Mambatek adjustable wastegate (12 psi spring)
TurboSmart Kompact Recirculating BOV
Racer X Front Mount Intercooler (2", 2.5") through OEM Opening
Factory Airbox with Drop in filter
Perrin 3" Silicone inlet
Injector Dynamics 1000cc (ID1000) cleaned less than 2K miles
DW300 Fuel Pump - New filters
3" Cobb Downpipe 3" straight through
Custom High Flow Cat (vibrant 3") and 3" Vibrant Ultra Quiet resonator placed in removable section of midpipe. (straight pipe is available)
3" Exhaust Y to Dual 2.5" exhaust (crush bent) reduced to factory 2014 Sti sedan mufflers 2.5 to oem size reduction 6" before cans
Perrin Equal Length Header and Uppipe (ceramic Coated) Normal Tube size
TGV Deletes
Air Pump deleted
Cobb 3 port boost control solenoid
AEM Wideband O2
NGK iridium factory heat plugs
Owner: KeithC
Rom: A2TB002C
Tyres: 235/45-18
Driver Weight: 90kg
XRT ECU Stage 3
XRT 5EAT Tuning
TGV Deletes
Air Pump deleted
AEM Wideband O2
