MichalC - 2007 EDM Subaru Impreza WRX STI 2.2L 2.0/2.5 Hybrid 6MT
Posted: Sun Feb 11, 2018 12:15 pm
Owner: MichalC
Rom: A8DH200Z
Tyres: 225/45r17
Car Weight: 1495kg
Driver Weight: 70kg
Total Weight: 1565kg
Displacement: 2.2L
EJ20 closed deck w/ EJ257 heads
EJ257 Nitrited crank
Mahle stroker pistons
OEM Spec-C main bearings
Mahle WRC-spec rod bearings
AVCS heads (intake) (EJ257)
TGV deletes
Injector Dynamics ID1050x
Fuel Pump Walbro 255lph
Stock fuel pressure regulator
stock EJ257 intake and sensors
ATP GT3071R turbo stock location
Stock STI TMIC
Forge BOV
Cobb 3-Port EBCS
3" bellmouth dp no cat
3" straight through exhaust
Mishimoto cooler
Spec-C IC auto spray
Turbo related info
Posted: Sun Feb 11, 2018 12:27 pm
v0 3rd Gear Dyno
Posted: Sat Apr 28, 2018 4:28 pm
v0 3rd Gear Dyno Critical Data.png (14.7 KiB) Viewed 18025 times
v0 3rd Gear Dyno @ 11.5psi.png (32.45 KiB) Viewed 18025 times
Re: MichalC - 2007 EDM Subaru Impreza WRX STI 2.0/2.5 Hybrid 6MT
Posted: Tue May 01, 2018 6:14 am
The stock EBC is being replace w/ 3-port EBCS
13psi vs 11.2psi - 3rd Gear Dyno SAE
Posted: Sun May 06, 2018 8:03 pm
v3 3rd Gear Dyno SAE @ 13psi.png (39.7 KiB) Viewed 17979 times
Posted: Sat Jun 16, 2018 6:50 am
Awaiting MAF housing upgrade.
Upgraded 70mm MAF
Posted: Sat Sep 22, 2018 8:14 am
70mm MAF.jpeg (123.45 KiB) Viewed 17651 times
v5a 3rd Gear Dyno SAE
Posted: Sun Nov 11, 2018 7:39 am
v5a 3rd Gear Dyno SAE.png (76.78 KiB) Viewed 17580 times
