JeffR - 2008 USDM Subaru Legacy Outback XT 2.5 5EAT - Tuning
Owner: JeffR
Rom: A2TB001C
Tyres: 225/55-R17
Car Weight: 1635kg
Driver Weight: 96kg
Total Weight: 1731kg
Engine Power
Maximum output @ Crank kW (HP)/rpm: 185 (245)/6,600
Maximum torque @ Crank N·m (kgf-m, ft-lb)/rpm: 327 (33.3, 241)/3,600
Cobb CAI
Cobb Catted Downpipe
v2d 3rd Gear Dyno SAE
v2d 2nd Gear Dyno SAE.png (35.49 KiB) Viewed 11255 times
jrob51
Post by jrob51 »
Ed is great to work with. Very helpful setting up logging parameters and explaining what you need next. Very capable on the programming end and very impressive in his ability to dig the pertinent information out of your logs.
I came to Ed because of some strange things my 5eat transmission was doing after my car was tuned by another tuner. So far he has improved the shifting characteristics and the acceleration curve. The drive by wire delays are gone and manual mode shifting now acts like the shift lever is actually connected to the transmission.
After Ed found that I was experiencing excessive back pressure (original exhaust with 150,000 miles on it) and a partially plugged catalytic converter, I replaced the exhaust and ran a catalyst cleaner through the system. Big increase in both power and fuel economy. Looking forward to the next steps.
The acceleration on the latest rom is so fun I can't confirm current fuel economy but I was seeing 30mpg at 70mph on flat ground
Return to “Outback XT”
