LogieH - 2005 USDM Subaru Legacy Outback XT 2.5 5MT - Tuning
Owner: LogieH
Rom: A2WC522S
Tyres: 225/55r17
Car Weight: 1546kg
Driver Weight: 107kg
Total Weight: 1653kg
Engine Power
Maximum output @ Crank kW (HP)/rpm: 186 (250)/6,000
Maximum torque @ Crank N·m (kgf-m, ft-lb)/rpm: 339 (34.5, 250)/3,600
http://www.subaruoutback.org/forums/109 ... build.html
New Subaru shortblock with standard internals. Subaru p/n 10103AC030
Rebuilt B25 stock heads.
Stock length Power division valves
Beehive valve springs w/titanium retainers
Rebuilt BNR 16G turbo (VF 40)
Catless Perrin uppipe
Invidia 3" divorced catted downpipe
TGV Delete with OEM sidefeeds
Exedy FF502 lightweight flywheel
FJK1001 clutch
Perrin lightweight crank pully
Perrin silicone turbo intake
11mm Subaru oil pump
killerB oil uptake
New AVCS solenoids
Filtered turbo oil line
Weather data
v4 3rd Gear Dyno SAE
v4 3rd Gear Dyno SAE.png (23.26 KiB) Viewed 7741 times
Return to “Outback XT”
