BartoszB - 2004 EDM Subaru Outback H6 3.0R 5EAT - SC Tuning
Posted: Tue May 24, 2016 6:31 pm
Owner: BartoszB
Rom: D2ZS002E
Tyres: 205/50-17
Car Weight: 1525kg
Driver Weight: 70kg
Total Weight: 1595kg
- Rotrex C38-81
- 65mm Pulley
- Stock MAF mounted in 76mm pipe before SC
- 550x230x65mm Intercooler: http://fmic.pl/jednostronne/279-interco ... x65mm.html
- Cone filter
- Supertech 8.5:1 Pistons
- 76mm piping before SC, 63mm after (incl. IC)
- MAP mounted in stock place in intake manifold
- OEM Subaru Dump Valve (from Forester turbo), return pipe goes into pipe just before SC but after MAF
- Deatschwerks DW200 fuel pump
- STI Pink injectors
- Full (headers&catcack) custom 2.25" exhaust with 2 Magnaflow CATs
Weather data
Addition - https://www.wunderground.com/cgi-bin/fi ... CZKO3&MR=1
Rotrex C38-81
Posted: Tue May 24, 2016 6:52 pm
Power: 220-485kw (300-660hp)
Max Flow: 0.58 kg/s (1004CFM) (77lb/min)
Max Presure Ratio: 2.85
Re: BartoszB - 2004 EDM Subaru Outback H6 3.0R 5EAT - SC Tun
Posted: Thu Jul 14, 2016 6:35 pm
Good news. All leaks been sorted and MAF tubed changed from 76mm to 80mm.
In addition, the broken vacuum line to the Fuel Pressure Regulator was fixed. Idle is currently stable and correction perfect to this setup.
v4h H6 AFR Correction.png (13.64 KiB) Viewed 26316 times
v4h H6 AFR 5 Change.png (13.8 KiB) Viewed 26316 times
Re: BartoszB - 2004 EDM Subaru Outback H6 3.0R 5EAT - SC Tuning
Posted: Sun Apr 23, 2017 4:08 pm
Engine rebuild.
Posted: Mon Dec 04, 2017 8:56 pm
Fresh logs are in and we are slowly getting back on track.
Transmission update
Posted: Tue Feb 06, 2018 8:34 pm
Stock EUDM Legacy H6 MY07
TG5C7CVAAA
FD: 3.583
Posted: Sat Feb 10, 2018 2:39 pm
Tyres: 245/45r18
BartoszB v9 4th Gear Dyno.png (56.12 KiB) Viewed 24184 times
BartoszB v9 4th Gear Dyno Boost.png (23.9 KiB) Viewed 24184 times
BartoszB v9 4th Gear Dyno IAT.png (21.03 KiB) Viewed 24184 times
BartoszB v9 4th Gear Dyno VE.png (22.59 KiB) Viewed 24184 times
BartoszB v9 4th Gear Dyno Engine Flow.png (22.15 KiB) Viewed 24184 times
Posted: Sat Apr 14, 2018 9:03 am
Last dyno and we are at 380whp, but awaiting further logging, but the car been delivered to the owner on his B'day!
