So I had my raptor headers installed since september and ran into a couple problems a few months back. My coil packs gave out and I had an exhaust leak which both were later fixed.
Rom V9D - Ed took the time out to remap my ECU after the initial raptor tuning to improve my car the best way he can. We even tested race gas (95+) with additional roms to reduce pinging due to NYC gas quality. The car felt great but up in the rev range I can feel something missing. Plus I could visually see and feel the RPM stutter down for some reason on mild throttle.
After: Ed noticed that my car didnt show any significant gains prior to headers upgrade. With that being said, he helped me with the hunt to find out why. Come to find out, my motor is not holding compression possibly due to previous lean conditions which caused my valves to warp due to heat which happened before tuning. So now I am currently in possession of supertech 1+MM valves and springs, subaru oem valve seal gasket kit, and new plugs (coolant is splashing on current plugs) to resolve my problem with an upcoming rebuild. I have decided that i might also due a port and polish because the head of the motor will be off. Even though this was a disappointing find, i am excited to see what new found power my leggy will bring. Ed was and IS a big help throughout the process and always is honest can be.
Below are some pictures of the header install, cold air intake cut and fab (current), and upcoming mods.
- RaptorHeaders.jpg (120.71 KiB) Viewed 26675 times
- Cai.jpg (162.9 KiB) Viewed 26675 times
- SuperTechValves.jpg (116.15 KiB) Viewed 26675 times
- SuperTechSprings.jpg (123.92 KiB) Viewed 26675 times
