Subaru Legacy Outback 2.5XT
Posted: Thu Sep 25, 2014 7:02 am
Specs:- http://www.xtremeracingtuning.com/Infor ... 2.5_XT.pdf
Bore x Stroke : 99.5 mm x 79.0 mm
Displacement: 2.457 cc (150 cu. in.)
Compression ratio: 8.2:1
Valvetrain: Intake AVCS
Max. boost pressure: 13.5 psi (700 mm Hg)
Horsepower: 250 @ 6,000 rpm
Torque: 250 lb-ft. @ 3,600 rpm
5-speed automatic (5EAT)
1 - 3.540
2 - 2.264
3 - 1.471
4 - 1.000
5 - 0.834
Reverse: 2.370
Final drive ratio: 3.58 with viscous limited slip rear differential
1 - 3.540
2 - 2.264
3 - 1.471
4 - 1.000
5 - 0.834
Reverse: 2.370
