JayN - 2006 USDM Subaru Legacy Outback XT 2.5 5EAT - Tuning
Posted: Sat Aug 23, 2014 6:26 pm
Owner: JayN
Rom: A2WF200R
Tyres:225/55-R17
Car Weight: 1501kg
Driver Weight: 95kg
Total Weight: 1596kg
Specs:- http://www.xtremeracingtuning.com/Infor ... 2.5_XT.pdf
Bore x Stroke : 99.5 mm x 79.0 mm
Displacement: 2.457 cc (150 cu. in.)
Compression ratio: 8.2:1
Valvetrain: Intake AVCS
Max. boost pressure: 13.5 psi (700 mm Hg)
Horsepower: 250 @ 6,000 rpm
Torque: 250 lb-ft. @ 3,600 rpm
5-speed automatic (5EAT)
1 - 3.540
2 - 2.264
3 - 1.471
4 - 1.000
5 - 0.834
Reverse: 2.370
Final drive ratio: 3.58 with viscous limited slip rear differential
Stock
v4 Feedback
Posted: Sat Aug 30, 2014 3:13 pm
XRT v4 vs Stock - 2nd Gear Dyno SAE.png (90.21 KiB) Viewed 9888 times
