JamesN - 2008 Subaru Outback 2.5i NA 4EAT Auto USDM - Tuning
Owner:Papajam - USA
Rom: EZ1GC00B
Tyres: 225/55-17
Car Weight: 1542kg
Driver Weight: 61kg
Total Weight: 1603kg
1st = 2.785
2nd = 1.545
3rd = 1.000
4th = 0.694
Final drive = 4.444
Dyno based on Speed
2nd Gear Dyno SAE + Engine - VE & Flow
Date: Sun, 29 Sep 2013 19:28:05 -0400
Subject: RE: Subaru tuning
I lost audio with you so after a couple of minutes, I went for a test drive.
WOW!!! Fells like a different engine!
Cheers,
Jim
Sent: Tuesday, October 01, 2013 6:26 PM
In short, the engine feels a LOT different! There is more torque down low (where I need it) and the engine is more responsive to throttle inputs. It is what I thought the car should have been to begin with! I checked fuel mileage yesterday (actual) and it was 20.25MPG. Not good but I drove the car a bit harder than ‘usual’ and had the 2nd gear pull in there as well. Engine revs did not exceed about 4000 (except for the pull). Checked the actual mileage again today after a normal commute to work and back and it returned 25.96MPG in Sport mode. Not bad! Again, engine not exceeding about 4000RPM.
Cheers,
Jim
Sent: Wednesday, October 02, 2013 6:17 PM
Subject: RE: RE: Subaru tuning
After 3 days of driving the car, another difference is that when the gearbox is in normal mode, and accelerating under light throttle, upshifts occur at less than 2000RPM. This is a lower RPM than before the V0 tune. This NOT a complaint, just an observation. With the added torque down low after the V0 tune, the engine STILL responds better at this low RPM than it did before. This is a good thing!
Unlike our Alfa Romeo whose engine rarely goes below 4000RPM when moving, I drive the Subaru the opposite; the engine doesn’t see much above 4000RPM. I see the Outback as a fun commute/utility vehicle, not as a sports car so that’s how I drive it. Reasonably good power (V0 made a big improvement) and good fuel economy.
v0 Engine VE
v0 Engine VE
v0 Engine VE.png (18.42 KiB) Viewed 14411 times
v0 2nd Gear Dyno SAE
v0 2nd Gear Dyno SAE.png (33.98 KiB) Viewed 14402 times
V1 Stats
Sent: Tuesday, October 08, 2013 7:36 PM
Subject: RE: Re: v1
All I can say for now is that the engine feels GREAT! The low end is FAR better than stock. And on about half throttle in 1st gear Sport mode, it felt like the engine came ‘on cam’ about 4000RPM. It simply took off!!  Mileage increased from yesterday’s 22.35 to 25.76
v1 2nd Gear Dyno SAE.png (43.04 KiB) Viewed 14389 times
Re: JamesN - 2008 Subaru Outback 2.5i NA 4EAT Auto USDM - Tu
Sent: Saturday, November 23, 2013 10:50 AM
To: west_minist
Subject: RE: v3
Good morning!
Well, it’s been a heck of a time these past 3 weeks including this past week with no emails or internet.
The car runs fantastic! Starts instantly and idles perfectly both cold and hot. Much, much improved low end power which, rarely going much over 3k RPM now, is where I need it. Light throttle upshifts occur at a low 2000 (approx) RPM which I think (if memory serves) is lower than the stock tune. This is NOT an issue mind you; just an observation. Doesn’t matter either because of the increase in low end power. And it may contribute to better MPG.
Speaking of MPG, the first full tank with the V3 tune netted 24.81. Not bad! The 2nd tank was low at 23.44 BUT every year around this time I use the 7 or so gallons of stabilized fuel I store for the generator, lawn mower, snow blower, etc. The 3rd tank, having just filled up yesterday, yielded the best mileage I’ve gotten with the car since we bought it this past August; 25.84 MPG. And this was with ambient temps, on a few mornings, being a bit below 0C! All 3 tanks were run the same; to and from work on the same roads and at the same speeds. About 2/3 of my commute is on the highway at 75-80 MPH (just under 3000 RPM).
Cheers,
