Professor XRT Subaru STI-04 w/ XRT-GpN Variant ROM w/ LC+AL
2001+ Subaru STI
http://www.xtremeracingtuning.com/forum ... f=87&t=315
Owner: Professor
Tyres: 235/45-17
Total Weight: 1614kg
2006 STI Spec C engine swapped into a 2004 STI Spec C
  • FMIC
  • AVO Wastegate - 15psi set
  • Blitz Boost Controller
  • Perrin Intake
  • Full HKS Turbo-back 3" Exhaust system
v6 Low boost setting up to 20psi
The car is running very efficient for a low boost setting. Typical an STI does 242-270+WHP
v6 Low Boost Setting.png (68.3 KiB) Viewed 21213 times
v6 Low Boost - Critical stats.png (61.31 KiB) Viewed 21213 times
v6 3rd Gear Dynoes SAE - Correct tyres.png (47.59 KiB) Viewed 21213 times
XRT Subaru WRX/STi Dominator 1.5XT-R Twinscroll Turbocharger
New Mods Application: Subaru WRX/STi JDM Twin Scroll Turbocharger
Horsepower: 470HP
Specs - http://www.xtremeracingtuning.com/forum ... ?f=8&t=450
  • Garrett Ball bearing CHRA
  • 56.5mm Turbine Wheel
  • 71mm XT Compressor wheel
  • 47lbs per min
  • BPT Twin Scroll Turbine housing
Target AFR = 11.98
IAT = 68C to 50C
Inj Max. Duty = approx. 60%
v10 4th Gear Dyno SAE 29PSI.png (22.89 KiB) Viewed 21107 times
Correction Factor set to 1
v11 3rd Gear Dyno SAE 19PSI.png (25.34 KiB) Viewed 21104 times
v13 Dynoes
v13 3rd Gear Dyno SAE 24PSI.png (21.8 KiB) Viewed 21085 times
v13 4th Gear Dyno SAE 26PSI.png (23.13 KiB) Viewed 21085 times
v16 3rd Gear Dyno SAE Boost=25PSI
v16 3rd Gear Dynoes SAE 25PSI.png (26.56 KiB) Viewed 20938 times
Re: Professor XRT Subaru STI-04 w/ XRT-GpN Variant ROM w/ LC
XRT-GpN v17 - 3rd Gear Dyno SAE @ 26psi.png (45.76 KiB) Viewed 20244 times
Subject: RE: Speed Density
Date: Sun, 27 Apr 2014 12:27:48 +0000
To: Xtreme Racing Tuning
Hi Edward, as usual, you rose to the challenge, thanks for your quick response to my request for tuning my car with the new TMIC etc. While we have not completed the tuning, the car is purring, running smoothly, no bucking. Even at low boost, the response is quite good. I can't wait to do the other minor changes and complete the tuning. I am once more a happy camper, and I am thinking of maybe running D & W on may 25th. Both the Car and Driver feel revitalized. Lol.
