RyanF - XRT Subaru STI-03 w/ XRT-GpN Variant ROM w/ LC+AL
2001+ Subaru STI
Video - http://www.youtube.com/watch?v=wbaoaG3OyWs
2004 JDM WRX w/ 2005 STi Engine
  • FP 68HTA Turbo
  • Perrin EL Header & Wrap
  • HKS HI-Power Turboback. DP wrap
  • AEM Meth/Water Injection. 50/50
  • AEM CAI
  • Sparco Big TMIC
  • Boost setup: Controller between the WG and Compressor
  • Elevation: Close to sea level
SD Mapping 1.png (106.64 KiB) Viewed 18405 times
SD Mapping 1_1.png (76.85 KiB) Viewed 18405 times
Re: XRT Subaru STI-03 w/ XRT-GpN Variant ROM w/ LC + AL
v16 SD.png (79.49 KiB) Viewed 18401 times
v16 SD-diff.png (54.83 KiB) Viewed 18401 times
sd log mapping.png (73.85 KiB) Viewed 18401 times
SD config from SD Engine Load
SD Calc from SD Eng Load.png (92.41 KiB) Viewed 18389 times
SD Calc from SD Eng Load - mapping.png (110.73 KiB) Viewed 18389 times
v17 SD MAP
v17-SD Map.png (79.06 KiB) Viewed 18382 times
v17-SD Map-main.png (57 KiB) Viewed 18382 times
v17 vs v18 SD 3D Map
v17 SD.png (52.49 KiB) Viewed 18382 times
v18 SD.png (47.5 KiB) Viewed 18382 times
v19 SD: To be tested
Still a lot of work for idling and cruising
v19 SD.png (53.56 KiB) Viewed 18382 times
v18 3rd Gear Dyno
sti-v28g-coolant 3rd Gear Dyno SAE.png (22.37 KiB) Viewed 17548 times
sti-v24 4th vs 3rd Dynoes SAE #1.png (55.26 KiB) Viewed 17505 times
