Synott - 2007 ADM Subaru Legacy 3R 6MT - Tuning
Owner: Synott
Rom: D2UH001M
Tyres: 215/45R18
Car Weight: 1510kg
Driver Weight: 93kg
Total Weight:1603 kg
XForce Cat-back Exhaust
Stock Stats
To be posted
v0 Stats
For the Dyno, total weight in the car was 163kg. 1/4 Tank of 98 Gas.
V0 Engines Stats.png (25.68 KiB) Viewed 12505 times
v1 Stats
Full tank of Gas. Doesn't seem the same quality. IAM is now at 1. So all the ign Adv. is being added now.
V1 Engines Stats.png (25.94 KiB) Viewed 12505 times
v1 3rd Gear Dyno SAE.png (16.11 KiB) Viewed 12063 times
v2 Stats
V2 Engines Stats.png (23.91 KiB) Viewed 12505 times
When the dyno was performed, I am not sure if the customer brake. The rpm and speed at the point stop climbing.
v2 3rd Gear Dyno IAT=44-41C.png (14.03 KiB) Viewed 12505 times
v3 Stats
Ok. Logs getting slowly clean.
V3 Engines Stats.png (24.63 KiB) Viewed 12505 times
v3 3rd Gear Dyno SAE.png (16.13 KiB) Viewed 12063 times
Customer Response
“Car is driving great, notice huge difference in low end”
Scv9 vs NA-v2 3rd Gear Dyno SAE
A better cooler to be install + minor exhaust leaks to be rectified
scv9 vs NA-v2 - 3rd Gear Dyno SAE.png (58.49 KiB) Viewed 12030 times
Boost @ 5+psi
