ez30rb - 2005 ADM Subaru Liberty 3R 6MT - Tuning
Owner: ez30rb
Rom: D2WD603H
Tyres: 225/35-19
Car Weight: 1510kg
Driver Weight: 85kg
Total Weight: 1595kg
HKS Panel Filter
Hi Tech Quad Exhausts
2nd Gear Dyno Stock IAT=25C.png (16.12 KiB) Viewed 13342 times
Still downhill in the end, which would rise power a bit
3rd Gear Dyno Stock IAT=20C.png (16.7 KiB) Viewed 13341 times
Stock performance.png (19.61 KiB) Viewed 13342 times
V1 feedback
http://forum.liberty.asn.au/viewtopic.p ... 82#p132104
EZ30RB wrote:Edward sent me a v1 this morning, and can say that the improvements are fantastic. The car pulls smoother and harder down low between 2-4K, picking up speed much easier than before and the flat feeling you get occasionally is gone. Pedal feel is better and more crisp, and you don't need as much pressure to build up speed. Higher revs also feels more crisp and elastic and the engine sounds great on song. I found myself wanting to go faster and faster ;) This is only v1 as well!
v1 vs stock - 3rd gear Dyno.png (19.91 KiB) Viewed 13337 times
v1 3rd Gear Dyno IAT=19C.png (16.63 KiB) Viewed 13337 times
v1 stats.png (21.35 KiB) Viewed 13337 times
v3 Stats
v3 stats.png (19.49 KiB) Viewed 13331 times
Re: ez30rb - 2005 ADM Subaru Liberty 3R 6MT - Tuning
http://forum.liberty.asn.au/viewtopic.p ... 94#p132288
EZ30RB wrote:v3 is uploaded. The engine note has changed and sounds stronger and more roar up high. Very nice.
In gear acceleration feels stronger and more responsive.
Totally different and completely better drive compared to stock.
v5 Stats
v5 2nd Gear Dyno IAT=14C.png (16.05 KiB) Viewed 13328 times
http://forum.liberty.asn.au/viewtopic.p ... 82#p132470
ez30rb wrote:Tuning is pretty much complete.
With V5, the car is a pleasure to drive. I don't want to stop driving and cannot help push the car hard as the power delivery is so much smoother and stronger.
The final v6 is to be uploaded later today.
http://forum.liberty.asn.au/viewtopic.p ... 82#p134122
ez30rb wrote:After some more fine tuning, we've arrived at v10 which included some ign fixes for when high speed cruising.
Driving impressions - Pedal feel is just right, and power is smooth and consistent. Edward from XRT is a friendly guy, and knows his stuff. If you own an H6, I highly recommend the services by Edward. If you've had the Upper Engine Cleaner done before, having it tuned feels like that and much more.
Below is a V9 3rd Gear Pull done on a very slightly inclined road.
