Owner: Professor
Tyres: 225/45-17
Total Weight: 1575kg
2006 STI Spec engine swapped into a 2004 STI Spec
FMIC
AVO Wastegate - 15psi set
Blitz Boost Controller
Perrin Intake
Full Turbo-back 3" Exhaust system
Professor - 2006 JDM Subaru STI Spec C
- Attachments
- Combine 4th Gear Runs.png (19.68 KiB) Viewed 14536 times
- 3rd Gear Dyno - Mix gas.png (17.36 KiB) Viewed 14536 times
West_Minist
Subaru Expert Tuner
info@xtremeracingtuning.com
Viciously Tuned, Driven Hard
Subaru Expert Tuner
2006 JDM Subaru STI Spec C - XRT-Tuned R-0
R version 0 @ 18.5psi
- Attachments
- 3rd Gear Dynoes combine - 18.5psi.png (18.45 KiB) Viewed 14525 times
2006 JDM Subaru STI Spec C - XRT-Tuned R-1
R-1 Results
- Attachments
- R-1 3rd Gear Dyno 18.5psi.png (16.74 KiB) Viewed 14524 times
West_Minist
Subaru Expert Tuner
Subaru Expert Tuner
Professor - 2006 JDM Subaru STI Spec C w/ Blouch Dom 1.5TS
http://www.xtremeracingtuning.com/forum ... =110&t=419
New Mods
Horsepower: 470HP
Specs
IAT = 68C to 50C
Inj Max. Duty = approx. 60%
New Mods
- ID1000 Injectors
- Subaru WRX/STi Dominator 1.5XT-R Twinscroll Turbocharger
Horsepower: 470HP
Specs
- Garrett Ball bearing CHRA
- 56.5mm Turbine Wheel
- 71mm XT Compressor wheel
- 47lbs per min
- BPT Twin Scroll Turbine housing
IAT = 68C to 50C
Subject: RE: Speed Density
Date: Sun, 27 Apr 2014 12:27:48 +0000
To: Xtreme Racing Tuning
Hi Edward, as usual, you rose to the challenge, thanks for your quick response to my request for tuning my car with the new TMIC etc. While we have not completed the tuning, the car is purring, running smoothly, no bucking. Even at low boost, the response is quite good. I can't wait to do the other minor changes and complete the tuning. I am once more a happy camper, and I am thinking of maybe running D & W on may 25th. Both the Car and Driver feel revitalized. Lol.
