AndriesS - 2004 JDM Subaru Legacy LGT 2.0 6MT
Owner: AndriesS
Rom: A2WD012B
Tyres: 245/45/R17
Car Kerb Weight: 1452kg
Driver Weight: 100kg
Total Weight: 1683kg
https://www.facebook.com/XtremeRacingTu ... 5684112289
Cylinder head quad avcs:
1) Stock valves.
2) Ported intake and exhaust ports. Should flow as much as a gdb sti spec c head.
3) Tomei poncam in&ex (p/n: 143070).
4) Tomei valve springs (p/n: 163057).
5) ARP head studs.
Cylinder block
1) Wiseco 92.5 mm pistons, measured ptw = .0026". Static compression ratio should be around 8.3:1
2) Manley H Tuff rods.
3) King XPG main and rod bearings.
4) Stock 12mm oil pump.
5) Stock ej20 crankshaft.
6) Ej205 case halves (open deck).
Fuel
1) Dw65c in tank fuel pump.
2) Injector dynamics id1050x.
3) Injector dynamics top feed fuel rail.
4) Stock FPR
5) Aquamist HFS4 water methanol injection system.
Turbo & exhaust
1) Borg warner efr 7163 twin scroll turbo with internal wastegate.
2) Turbosmart dual port wastegate actuator with 7 psi spring.
3) Full-Race MAC 4 port ebcs
4) Stock legacy twin scroll manifold and up pipe. (Needs upgrading)
5) 3" turbo back exhaust
Ignition
1) Stock coil packs
2) NGK lfr7aix plugs with stock gap .031"
Intake
1) MRP Mass Air Flow Housing 3.50” (90mm) OD x 4.625”(118mm) tube
2) 2010 Legacy 3.6 MAF Sensor
3) Omni 4 bar map sensor
4) Garrett Front mount intercooler - https://www.atpturbo.com/mm5/merchant.m ... y_Code=INT
Electronics
1) AEM uego wideband (can log through romraider).
2) Defi boost gauge
1) 2003 jdm sti 6mt
Re: AndriesS - 2004 JDM Subaru Legacy LGT 2.0 6MT
Expected oil change at 500km on Monday/Tuesday. So far so good based on preliminary data.
v3b 3rd Gear Dyno SAE
v3b 3rd Gear Dyno SAE.png (50.29 KiB) Viewed 13358 times
v9 3rd Gear Dyno SAE @ avg 24psi
v9 3rd Gear Dyno SAE @ 24psi.png (32.38 KiB) Viewed 13295 times
v10a 3rd Gear Dyno SAE @ avg 30psi
v10a 3rd Gear Dyno SAE @ avg 30psi.png (32.46 KiB) Viewed 13294 times
