EricY - 2004 USDM Subaru STI 6MT
Subaru STI 2004+
Owner: EricY
Version: v3
Tyres: 265/35R18
Car Weight: 1506kg
Driver Weight: 91kg
Total Weight: 1597kg
https://www.facebook.com/XtremeRacingTu ... 3555493501
04 Subaru Impreza WRX STi with 71k km, stock block, ARP head studs & valve adjustment a year ago:
Blouch Dom 1.5 8cm XT-R
ID 1000cc Injectors with top feed conversion & parallel hose routing
Perrin FMIC
TGV delete
Tomei EL header with 38mm EWG (12psi springs)
Grimmspeed EBCS with cobb 1/4" ewg hose kit
COBB intake (no box)
COBB TBE
Walbro 255 fuel pump
Cosworth thermostat
IAG AOS
Custom oil cooler
Koyo rad
Killer B oil pan combo
AEM WB 30-0300
AEM IAT 30-2010
Omni map-sti-4bar
v5 3rd Gear Dyno SAE @ 18.5psi
v5 3rd Gear Dyno SAE @ 18.5psi.png (37.12 KiB) Viewed 15898 times
v13 Race Pulls - Dynoes
v13 Race Pulls Power.png (100.61 KiB) Viewed 15853 times
Re: EricY - 2004 USDM Subaru STI 6MT
WhatsApp Image 2018-05-16 at 12.27.04 PM.jpeg (290.62 KiB) Viewed 15805 times
WhatsApp Image 2018-05-16 at 12.27.04 PM(1).jpeg (177.52 KiB) Viewed 15805 times
v1d 3rd Gear Dyno SAE
v1d 3rd Gear Dyno SAE.png (55.4 KiB) Viewed 15558 times
