MichalC - 2007 EDM Subaru Impreza WRX STI 2.2L 2.0/2.5 Hybrid 6MT
2001+ Subaru STI
Owner: MichalC
Rom: A8DH200Z
Tyres: 225/45r17
Car Weight: 1495kg
Driver Weight: 70kg
Total Weight: 1565kg
Displacement: 2.2L
EJ20 closed deck w/ EJ257 heads
EJ257 Nitrited crank
Manley rods
Mahle stroker pistons
OEM Spec-C main bearings
Mahle WRC-spec rod bearings
AVCS heads (intake) (EJ257)
TGV deletes
Injector Dynamics ID1050x
Fuel Pump Walbro 255lph
Stock fuel pressure regulator
stock EJ257 intake and sensors
ATP GT3071R turbo stock location
Stock STI TMIC
Forge BOV
Cobb 3-Port EBCS
3" bellmouth dp no cat
3" straight through exhaust
Mishimoto cooler
Spec-C IC auto spray
Turbo related info
v0 3rd Gear Dyno
v0 3rd Gear Dyno Critical Data.png (14.7 KiB) Viewed 18040 times
v0 3rd Gear Dyno @ 11.5psi.png (32.45 KiB) Viewed 18040 times
Re: MichalC - 2007 EDM Subaru Impreza WRX STI 2.0/2.5 Hybrid 6MT
The stock EBC is being replace w/ 3-port EBCS
Cobb EBCS.png (206.49 KiB) Viewed 18002 times
13psi vs 11.2psi - 3rd Gear Dyno SAE
v3 3rd Gear Dyno SAE @ 13psi.png (39.7 KiB) Viewed 17994 times
Awaiting MAF housing upgrade.
Upgraded 70mm MAF
70mm MAF.jpeg (123.45 KiB) Viewed 17666 times
v5a 3rd Gear Dyno SAE
v5a 3rd Gear Dyno SAE.png (76.78 KiB) Viewed 17595 times
