JasonW - 2004 JDM Impreza WRX STI 2.0L 6MT - GpN Tuning
2001+ Subaru STI
Owner: JasonW
Rom:CarBerry
Tyres: 235/45-17
Car Weight: 1477kg
Driver Weight: 73kg
Total Weight: 1550kg
Stock
Blitz SBC Boost COntroller
Tuned: XRT Group N Rally w/ MAF, AL, LC
3rd Gear Pulls Stats #1.png (22.71 KiB) Viewed 21508 times
3rd Gear Pulls Stats #2.png (20.68 KiB) Viewed 21508 times
3rd Gear Pulls Stats #3.png (38.26 KiB) Viewed 21506 times
3rd Gear Pulls Stats #4.png (43.68 KiB) Viewed 21506 times
Stock 3rd Gear Dyno SAE.png (32.41 KiB) Viewed 21497 times
New Modifications
New Mods Application: Subaru WRX/STi JDM Twin Scroll Turbocharger
Horsepower: 470HP
Specs - http://www.xtremeracingtuning.com/forum ... ?f=8&t=450
  • Custom low friction low inertia ceramic ball bearing CHRA
  • Custom high flow low inertia 56.5mm turbine wheel
  • 71mm XT Compressor wheel
  • 47lbs per min
  • BPT Twin Scroll Turbine housing
v2 @ wastegate pressure
Still under wastegate pressure of 15psi by 2psi and way under normal operating boost of 19-20psi.
GpN2v2 4th Gear Dyno SAE.png (46.84 KiB) Viewed 21317 times
Re: JasonW - 2004 JDM Impreza WRX STI 2.0L 6MT - GpN Tuning
We discovered issues with the stock BOV opening at 5psi. This will be fix.
Update 2017-03-17
We are still suffer boost issues and need to review for exhaust header leaks, including the wastegate operations.
Update: 2017-07-09
A new Turboback system was installed and all flow issues been fix. Tuning has restarted and we are now reaching MAF limit and will blend to VE very soon.
Blouch Dom 1.5XTR TwinScroll @ 21psi | IAT-33C
BlouchDom15XTR-TS @ 21psi-IAT-33C.png (30.76 KiB) Viewed 20914 times
v13e 3rd Gear Dyno SAE @ 25.5psi | IAT=30C
v13e 3rd Gear Dyno SAE @ 25.5psi.png (38.95 KiB) Viewed 20729 times
v16a 3rd Gear Dyno SAE
v16a 3rd Gear Dyno SAE.png (22.91 KiB) Viewed 20583 times
GSC Cams recommendation
GSC Power-Division S1 camshafts for the EJ20 JDM/EURO 2.0L STi.
https://www.power-division.com/gsc-powe ... -avcs.html
Intake 268 / 225 @ .040" / Peak Lift 10.8mm / Centerline 130
Exhaust 266 / 224 @ .040" / Peak Lift 10.4mm / Centerline 113
