32bit ECU - H6 3.0R
A/F Correction #1 (%)
A/F Correction #2 (%)
A/F Learning #1 (%)
A/F Learning #2 (%)
A/F Sensor #1 (AFR)
A/F Sensor #2 (AFR)
Accelerator Pedal Angle (%)
Coolant Temperature (C)
Engine Load (Calculated) (g/rev)
Engine Speed (rpm)
Fine Learning Knock Correction (degrees)
IAM (multiplier)
Ignition Total Timing (degrees)
Injector Duty Cycle (%)
Intake Air Temperature (C)
Intake VVT Advance Angle Left (degrees)
Intake VVT Advance Angle Right (degrees)
Learned Ignition Timing (degrees)
Manifold Absolute Pressure (psi)
Mass Airflow (g/s)
Mass Airflow Sensor Voltage (V)
Oil Temperature (C)
Throttle Opening Angle (%)
Vehicle Speed (km/h)
Logging Parameters for RomRaider
2012+ H6 3.6R
A/F Learning #1 (%)
A/F Learning #2 (%)
A/F Sensor #1 (AFR)
A/F Sensor #2 (AFR)
Engine Speed (rpm)
Exhaust VVT Advance Angle Left (degrees)
Exhaust VVT Advance Angle Right (degrees)
IAM (multiplier)
Mass Airflow (g/s)
A/F Learning #1 (%)
A/F Learning #2 (%)
A/F Sensor #1 (AFR)
A/F Sensor #2 (AFR)
Engine Speed (rpm)
IAM (multiplier)
Mass Airflow (g/s)
16bit ECU
A/F Learning #1 (%)
A/F Sensor #1 (AFR)
Engine Load
Engine Speed (rpm)
Feedback Knock Correction* (degrees)
Fine Learning Knock Correction* (degrees)
Gear (Calculated)* (position)
IAM* (raw ecu value)
Knock Correction Advance (degrees)
Manifold Relative Pressure (Direct)* (psi relative)
Mass Airflow (g/s)
Primary Wastegate Duty Cycle (%)
Vehicle Speed (kph)
A/F Learning #1 (%)
A/F Sensor #1 (AFR)
Engine Load
Engine Speed (rpm)
Mass Airflow (g/s)
Vehicle Speed (kph)
32bit - Turbocharge (Legacy GT, Forester XT, WRX, STI)
A/F Learning #1 (%)
A/F Sensor #1 (AFR)
Battery Voltage (V)
Engine Load (4-Byte)* (g/rev)
Engine Speed (rpm)
Feedback Knock Correction (1-byte)** (degrees)
Fine Learning Knock Correction (1-byte)** (degrees)
IAM (1-byte)** (multiplier)
Manifold Relative Sea Level Pressure (Direct)
Mass Airflow (g/s)
Vehicle Speed (kph)
Innovate Wideband AFR (AFR Gasoline)
A/F Learning #1 (%)
A/F Sensor #1 (AFR)
Battery Voltage (V)
Engine Speed (rpm)
Mass Airflow (g/s)
Vehicle Speed (kph)
CarBerry/GpN Logging
A/F Learning #1 (%)
A/F Sensor #1 (AFR)
CL/OL Fueling* (status)
Closed Loop Fueling Target* (AFR)
Cylinder-1 Knock Count (Knock Events)
Cylinder-2 Knock Count (Knock Events)
Cylinder-3 Knock Count (Knock Events)
Cylinder-4 Knock Count (Knock Events)
Engine Speed (rpm)
Engine Load* (grev)
Fueling Final Base* (estimated AFR)
Manifold Absolute Pressure (Direct)* (psi absolute)
Mass Airflow (g/s)
Throttle Sensor Voltage (V)
Tip-in Throttle* (%)
Vehicle Speed (kph)
Volumetric Efficiency* (Load Multiplier)
A/F Sensor #1 (AFR)
Engine Speed (rpm)
Engine Load* (grev)
Mass Airflow (g/s)
Vehicle Speed (kph)
2015+ 3.6 Legacy/Outback
Ambient Air Temperature (°C)
Engine Speed (RPM)
Fuel Trim #1 - Long Term (%)
Fuel Trim #1 - Short Term (%)
Fuel Trim #2 - Long Term (%)
Fuel Trim #2 - Short Term (%)
Fuel/Air Commanded (AFR Gas)
Intake Manifold Pressure (psi)
Mass Airflow (g/s)
O2 Wideband Bank 1 Sensor 1 (AFR Gas)
O2 Wideband Bank 2 Sensor 1 (AFR Gas)
Throttle Opening (Commanded) (%)
Timing Advance (degrees)
Engine Speed (RPM)
Mass Airflow (g/s)
