RobMc - 2005 EDM Subaru Legacy Spec B 3.0R 6MT - Tuning
Owner: RobMc
Rom: D2WD701C
Tyres: 225/40/18
Car Weight: 1480kg
Driver Weight: 92kg
Total Weight: 1570kg
Rebuilt engine with 0.5mm Oversize Pistons
Modified Intake Air collector w/ Cosworth panel air filter (using the standard air box)
Stainless steel exhaust - high flow silencers, no centre CAT and slightly larger diameter centre section but still uses the original (remaining) CAT’s
Raptor headers
LPG system which has its own ECU, injections and fuel system
Stock 3rd Gear Dyno SAE sm=2 tm=150.png (25.29 KiB) Viewed 3495 times
