GerryM - 2004 JDM Subaru Legacy 2.0GT 5EAT - Tuning
Owner: GerryM
Rom: A2ZJD02A
Tyres: 215/45-17
Car Weight: 1460kg
Driver Weight: 82kg
Total Weight: 1542kg
STI Genome Axle-back box
Cosworth panel filter
Kinugawa Billet Turbocharger SUBARU 06-07 Legacy Liberty TD04HL-20T Twin Scroll
  • Application
    - 06~07 BP5 / BL5 Legacy Liberty GT
    - Replace VF38, VF44, VF45
    - 20T billet wheel + 9 blade turbine wheel will spool fast and offer extra 10% extra airflow to get more HP.
    Bearing Type
    Journal Bearing / Performance Thrust Bearing Kit with larger thrust ring and flinger.
    Cooling System
    Water cooled
    Compressor Wheel
    47/58 mm (20T / 11 Blade Billet Wheel)
    Turbine Wheel 46/58 mm ( TD04HL / 9 Blade High Flow)
    Turbine Housing
    Twin Scroll 8.5cm Housing
    Wastegate Actuator
    - 1.0 Bar / 15 psi
    - 0.5Bar, 0.8 Bar, 1 Bar, 1.2 Bar, 1.5 bar actuators are available, please contact us if you need it.
V0 Tuning feedback
XRT v0 vs Stock Tuned.png (81.36 KiB) Viewed 16550 times
Wg actuator needs setting including checking for intake system leaks.
Re: GerryM - 2004 JDM Subaru Legacy 2.0GT 5EAT - Tuning
Updated Mods
https://www.facebook.com/XtremeRacingTu ... 7025576152
EJ20X 2006 version
Fuji racing Air pump delete plates
Kinugawa TD04HLA 20T
Power Enterprise Air Impulse II Air filter
TurboXS copy FMIC
Perrin Intake hose (PSP-INT-421BK)
Venair Silicone Throttle Body Hose (Black 620001120794-BK)
Cotosports BOV
Grimspeed boost solenoid
Deathwerks 65c fuel pump
Innovate LC-2 wideband
Cyber R power dual tube
Cyber R sports downpipe
225/40-18 Tyres
GerryM Customer Review.PNG (10.02 KiB) Viewed 12647 times
v7e 3rd Gear Dyno SAE.png (59.05 KiB) Viewed 12664 times
Pics
GerryM - 2004 JDM Subaru Legacy GT 2.0 5EAT #5.jpeg (196.78 KiB) Viewed 12654 times
GerryM - 2004 JDM Subaru Legacy GT 2.0 5EAT #4.jpeg (205.4 KiB) Viewed 12654 times
GerryM - 2004 JDM Subaru Legacy GT 2.0 5EAT #3.jpeg (75.36 KiB) Viewed 12654 times
GerryM - 2004 JDM Subaru Legacy GT 2.0 5EAT #2.jpeg (168.11 KiB) Viewed 12654 times
GerryM - 2004 JDM Subaru Legacy GT 2.0 5EAT #1.jpeg (191.63 KiB) Viewed 12654 times
