RobertB - 2008 JDM Subaru Impreza 2.0 S-GT 5MT - Tuning
Owner: RobertB
Rom: A2TB100U
Tyres: 225/45R17
Car Weight: 1400kg
Driver Weight: 77kg
Tuner: 59kg
Total Weight:1536 kg
Decat DP
Custom Cat-back Exhaust
Perrin Intake
Perrin BOV
Body Kit
Engine VE in 3rd Gear.png (7.55 KiB) Viewed 28669 times
Engine Flow relative to Rel.boost.png (42.11 KiB) Viewed 28669 times
Engine Power relative to Engine Flow.png (60.1 KiB) Viewed 28669 times
Stock Data
Boost curve.png (11.15 KiB) Viewed 28703 times
Stock 2nd Gear Dyno SAE #1 v2.png (26.04 KiB) Viewed 28703 times
v5 Stats
v5 2nd Gear Dyno SAE Boost=17.5psi.png (17.07 KiB) Viewed 28699 times
v5 2nd Gear Dyno SAE Throttle.png (18.74 KiB) Viewed 28699 times
v5 2nd Gear Dyno SAE @ 17.5psi v2.png (23.82 KiB) Viewed 28669 times
v6 Dyno
v6 3rd Gear Dyno SAE.png (24.37 KiB) Viewed 28669 times
Re: RobertB - 2008 JDM Subaru Impreza 2.0 S-GT 5MT
Turbo IHI VF47 Turbo seems to be equivalent to the Garret GT2859R
2008 Subaru WRX 2.0 S-GT Compressor Mapping
2008 Subaru WRX 2.0 S-GT Compressor Mapping.png (185.47 KiB) Viewed 28176 times
v14 Dyno
The car is running a fuel mixture to increase octane. The results are shown below.
v14 3rd Gear Dyno Stats
v14 3rd Gear Dyno Stats.png (24.56 KiB) Viewed 28564 times
v14 3rd Gear Dyno SAE PSI=17.5 sm=2 tm=12
v14 3rd Gear Dyno SAE PSI=17.5 sm=2 tm=12.png (59.18 KiB) Viewed 28564 times
Re: RobertB - 2008 JDM Subaru Impreza 2.0 S-GT 5MT - Tuning
The car been retuned with a rev limit set to 5650 rpm. Boost been increased to 19.5-20psi to maximised the turbo sweet spot, tq and engine flow based on the driver needs. DBW changes been made to make the throttle run 100% at 30+% of accelerator. The torque is constantly around 300wftlb
v20 vs Stock - 3rd Gear Dyno SAE
v20 vs Stock - 3rd Gear Dyno SAE.png (41.8 KiB) Viewed 28516 times
VP RallyMax @ 20psi
vprm6 3rd Gear Dyno SAE sm=2 tm=150.png (34.07 KiB) Viewed 28214 times
Tyres: 245/45-17
Full catback Exhaust mods. Straight pipe
Audio clip of the car - http://www.xtremeracingtuning.com/MY08_ ... 0_down.mp3
XRT Tuned VP RallyMax @ 20psi
Nasioc vprm22 3rd Gear Dyno SAE sm=2 tm=150.png (32.03 KiB) Viewed 28033 times
