Blouch JDM EJ207 WRX/STi Dominator 1.5XTR Twinscroll Turbo
1/4 mile times, Dyno's, Time trials...
http://www.xtremeracingtuning.com/forum ... =107#p1302
A nice turbo for the 2004+ JDM STI with around 400+WHP @ 22+psi on tap.
Additional mods should include Perrin EBCS, Process West TMIC, ID850 Injectors
Subaru WRX/STi Dominator 1.5XT-R Twinscroll Turbocharger
Part Number SUB-1.5XT-R Twin Scroll
Description
  • Application: Blouch Subaru WRX/STi JDM Twin Scroll Turbocharger for JDM 2004+ EJ207
Specs
  • Horsepower: 470CHP
  • Garrett Ball bearing CHRA
  • 56.5mm Turbine Wheel
  • 71mm XT Compressor wheel
  • 47lbs per min
  • BPT Twin Scroll Turbine housing
Packaing: Turbo includes water pipes, oil feed line, and ported exhaust housing.
Requirements: JDM Twinscroll header, uppipe, downpipe needed for install
The turbo is equivalent to the Garret GT3071R Turbo and is very efficient between 18-25psi.
Code: Select all
Boost	15	16	  17	 19	 20	 22	 24	 25	 26	 28	 29	 31	32
PR	  2.0	2.1	2.2	2.3	2.4	2.5	2.6	2.7	2.8	2.9	3.0	3.1	3.2
Car: http://www.xtremeracingtuning.com/forum ... =419#p1338
Old Car: http://www.xtremeracingtuning.com/forum ... f=87&t=315
Owner: Professor
Tyres: 235/45-17
Total Weight: 1614kg
2006 JDM STI Spec C engine swapped into a 2004 JDM STI Spec C
  • FMIC
  • ID1000 Injectors
  • Subaru WRX/STi Dominator 1.5XT-R Twinscroll Turbocharger
  • Blitz Boost Controller
  • Perrin Intake
  • Full HKS Turbo-back 3" Exhaust system
Target AFR = 11.98
IAT = 68C to 50C
Inj Max. Duty = approx. 60%
Dynoes performed and varying roads, which affect results.
Dyno Correction Factor: Buschur Racing Mustang = 0.917
3rd Gear Dyno SAE 15PSI
GpN v15 3rd Gear Dyno SAE 15PSI.png (20.34 KiB) Viewed 36252 times
3rd Gear Dyno SAE 18PSI
GpN v9 3rd Gear Dyno SAE 18PSI.png (19.08 KiB) Viewed 36255 times
3rd Gear Dyno SAE 25PSI
v16 3rd Gear Dyno SAE 25PSI #1.png (23.1 KiB) Viewed 36228 times
3rd Gear Dyno SAE 26PSI
3rd Gear Dyno SAE 26PSI.png (19.25 KiB) Viewed 36259 times
4th Gear Dyno SAE 21.5PSI
GpN v13 4th Gear Dyno SAE 21.5PSI.png (19.29 KiB) Viewed 36258 times
4th Gear Dyno SAE 26-to-24PSI
GpN v13 4th Gear Dyno SAE 26PSI-to-24PSI.png (19.59 KiB) Viewed 36256 times
4th Gear Dyno SAE 29PSI
GpN v10 4th Gear Dyno SAE 29PSI-to-25PSI.png (19.45 KiB) Viewed 36255 times
Full XRT Tuning @ 26PSI for v17 Rom
http://www.xtremeracingtuning.com/forum ... hp?id=1430
Subaru WRX/STi Dominator 3.0XT-R Twinscroll Turbocharger
Full Race can offer a TwinScroll GTX3071R. Recommendation been made for the GTX3071R
Recommendation to change to the Subaru WRX/STi Dominator 3.0XT-R Twinscroll Turbocharger have been made
http://www.bptstore.com/Subaru-WRXSTi-D ... p_135.html
If installed, I am expecting up to 500whp on pump gas w/ 50/50 water/meth on current mods. Otherwise achieve that results on race gas.
Application: Subaru WRX/STi JDM Twin Scroll Turbocharger
Horsepower: 550CHP
Specs
60mmTurbine Wheel
76mm XT Compressor wheel
55lbs per min
The Dom 3.0XT-R is equivalent to the GTX3071R (56lbs/min, 560CHP) but will spool slower since it carries a 76mm compressor. Its spool characteristics could be the same as the GT3076R (52lbs/min, 525CHP) but produces a little more power than that turbo.
Code: Select all
Return to “Proven Power Bragging”
