PaulB - 2008 African Subaru Tribeca B9 3.0R 5EAT - Tuning
Owner: PaulB
Rom: D2UJ001D
Tyres: P255/55R18
Car Weight: 1940kg
Driver Weight: 97kg
Total Weight: 2037kg
1st: 3.841
2nd: 2.352
3rd: 1.529
4th: 1
5th: 0.839
Final Drive: 3.583
Stock Stats
Critical Stats.png (20.64 KiB) Viewed 21094 times
Below shows you the tranny locking up @ 6000rpm. This is what it looks like for your education
For your viewing.png (24.15 KiB) Viewed 21081 times
For your viewing #1.png (58.43 KiB) Viewed 21081 times
Stock 3rd Gear Dyno IAT=37-33C.png (12.99 KiB) Viewed 20933 times
v0 Stats
v0 Stats.png (19.86 KiB) Viewed 21087 times
Based on v0 logs, slowly tuning out pinging.
PaulB
Re: PaulB - 2008 African Subaru Tribeca B9 3.0R 5EAT - Tunin
Post by PaulB »
Thanks Edward,
Can you explain the legend please, i.e. what does the green line represent and the same for the red line?
Regards
Paul
PaulB wrote:Thanks Edward,
Regards
Paul
There are two logs combined. The more the logs, the more the coloured lines.
All lines are self explanatory.
Explanation:- http://www.romraider.com/forum/topic4271.html
IAM: Varies how much ignition is added to the car based on how much pinging is detected. No pinging at all, the IAM=1. Pinging is happens due to Fuel quality, and poor engine maintenance. The Older the Oil, the more pinging you will have. Also please keep your fuel level close to full. Subarus are know to ping the lower the fuel level is.
FLKC: Show the ecu added and remove ign by degrees that was learnt.
PaulB
Post by PaulB »
Thanks, from that I assume that the shorter (red) line represents the first log of v0 and the green line the second log as that is the larger file?
As I travel the same road every time I find it interesting to map the log the the piece of road I was on. I also want to see if I can pin point the area in the log where it needed lots of persuasion (lots of throttle) to gear down.
A replay of the log shows it. You will not be able to see it from these graphs. 1st and last log.
I posted it to show you the pinging and the stability of the IAM. V1 should be a lot stable.
PaulB
Post by PaulB »
On the first log, the very first time I went to 6,000 rpm you see a dip just after 6,000rpm? What do you think that is? That is why I thought it shifted but can you confirm that my foot was still planted, i.e. and that I lifted off only after it had changed to 4th gear?
Thanks
Paul
PaulB
Post by PaulB »
Just to confirm that changing from 3rd to 4th gear from about 6000rpm should have at least a 1500 drop in rpm. I had a look yesterday. So what must have happened there at 6000rpm could only have been the torque converter. It was quite rough tough and felt more like a gear change than the converter locking up.
Anyway the new roms don't have this "glitch". Can you please post me the 3rd log of yesterday. I think it was a drag in 3rd gear from about 2500rpm.
Can you also please post the loss of power at 2500rpm that I felt yesterday. There was one that was quite bad and had the engine running very rough for a while. I'm quite keen to see what that looked like.
Thanks
Paul
PaulB
Post by PaulB »
Can you please post some comparative graphs to show what difference the octane booster had?
Thanks
Paul
