Bill - 2006 ADM Subaru Legacy 3R 6MT - Tuning
Owner: Bill - AUS
Rom: D0XJ001M
Tyres: 225/45-18
Car Weight: 1510kg
Driver Weight: 104kg
Total Weight: 1614kg
All dyno'es are based on Vehicle Speed.
Stock Performance @ 39-43C
Stock Critical Stats.png (25.88 KiB) Viewed 18600 times
Stock 3rd Dyno IAT=34C.png (17.38 KiB) Viewed 18586 times
Bill
Re: Bill - 2006 ADM Subaru Legacy 3R 6MT - Tuning
Post by Bill »
We started at v0 and even with this first version the improvement in performance was really good. Further revisions improve ignition timing and remove any knocking (or pinging) with continual fine tuning of the timing, avcs, fuel mixture and knock correction.
After taking the log of v3 I looked at the logs more closely and could see that the time to accelerate from 1500 rpm to 7000 rpm or 27 km/hr to 124 km/hr in third gear had gone from 13.1 sec to 11.9 sec.
We are up to v5 now and it feels like the engine is running much more sweetly than before, as well as with about 10kW more. I have had the rear mufflers changed to short straight through resonators so I can hear the exhaust note and it sounds nicer now too. Edward wanted me to return the ecu to the standard setup, or in other words, reload the standard Subaru ROM, do a log and then load the v5 ROM and do another log. So I have just done a test of one straight after the other and the car is so much nicer now, Edward has done a really good job of tuning the engine.
Edward has been really good to deal with and this way of tuning the car is good fun.
v5 3rd Gear Dyno
v5 3rd Gear Dyno IAT=34C.png (17.19 KiB) Viewed 18586 times
Dyno based on Speed
v5 3rd Gear Dyno IAT=34C rpm.png (17.33 KiB) Viewed 18586 times
Dyno based on RPM
You exhaust system seems a little restrictive. Fuel quality may not be like in other areas.
Stock vs v5
Stock vs v5 - 3rd Gear Dyno rpm #1.png (22.07 KiB) Viewed 18574 times
v8b - BP Octane Booster vs Mogas 100
I Think I like Mogas 100 since it was tested in hot weather and produce good results.
v8b 3rd Gear Dyno BP_OB vs MO_100.png (22.14 KiB) Viewed 18244 times
v9 vs v8b
V9 with new fuel map runs better at higher IAT temperature. Readjusted to increase tq below 3000rpm below.
Mogas is 100Octane with 5% Ethanol and easily attainable. I really think is 100Octane overall.
v9 vs v8b 3rd Gear Dyno Mo_100.png (20.49 KiB) Viewed 18243 times
v9 and v9a
V9 & v9a. V9a posted higher figures. Really due to temperature. Release v9b which contains just minor AVCS change and tuning is completed.
v9 3rd Gear Dynoes IAT=27-24C Mo_100.png (15.81 KiB) Viewed 18238 times
Bill
Post by Bill »
I had my car done last January (a full tune) and Edward just gave me an update of a later version incorporating some changes he has made since my car was done and he did it for free. The power delivery at part throttle is smoother, it doesn't come on so sudden now.
