Compliments to Hyper on this wonderful RA in Tuning
Thank you very much in giving me the opportunity to offer feedback to this car.
Cosworth AVCS Cams
GT3071R Twin-Scroll Turbo running 23psi with 17.5psi WG Spring
Apexi High Flow Panel Intake Filter (stock intake box)
PE800cc Injectors
Walbro Pump
Exhaust system
Hyper, you can notify on any corrections above.
Real Dyno can be up to 40whp less, but the graphs are very heavily smoothed.
Yellow & Red represents 4th Gear, while Orange and Green represents 3rd gear.
Hydra Drag RA 3th & 4th Gear Dynoes
Hyper Drag RA 11.8s car on street tires
West_Minist
Subaru Expert Tuner
info@xtremeracingtuning.com
Viciously Tuned, Driven Hard
Subaru Expert Tuner
Re: Hyper Drag RA 11.6s car on street tires
Same as above, but I added the 2nd gear to the graph.
Looking at the info table and starting from the top, results for 2nd, 3rd and 4th gear respectively.
- Attachments
- Hyper Drag RA - Dynoes.png (20.57 KiB) Viewed 8636 times
West_Minist
Subaru Expert Tuner
Subaru Expert Tuner
initially we used Apexi intake system, but it was so terribile we ended up switching back to stock airbox with Apexi panel filter
we also have HKS intake kit (which I honestly think is the best on the market) but no need for it at the moment, as we are still have to dial in other things like injectors and AFR
Re: Hyper Drag RA 11.8s car on street tires
Did you every tried the GT3076?
