Logging Parameters for RomRaider
Information related to tuning
User avatar
Post by west_minist » Mon Mar 10, 2014 7:19 am
32bit ECU - H6 3.0R
Accelerator Pedal Angle (%)
A/F Correction #1 (%)
A/F Correction #2 (%)
A/F Learning #1 (%)
A/F Learning #2 (%)
A/F Sensor #1 (AFR)
A/F Sensor #2 (AFR)
Coolant Temperature (C)
Engine Load (2-byte)** (g/rev)
Engine Speed (rpm)
Feedback Knock Correction (degrees)
Fine Learning Knock Correction (degrees)
Gear (Calculated)* (position)
IAM (1-byte)** (multiplier)
Ignition Total Timing (degrees)
Injector Duty Cycle (%)
Intake Air Temperature (C)
Intake VVT Advance Angle Left (degrees)
Intake VVT Advance Angle Right (degrees)
Knock Correction Advance (degrees)
Manifold Absolute Pressure (psi)
Mass Airflow (g/s)
Mass Airflow Sensor Voltage (V)
Oil Temperature (C)
Throttle Opening Angle (%)
Vehicle Speed (kph)
User avatar
2012+ H6 3.6R
Post by west_minist » Sun Oct 12, 2014 9:51 am
A/F Learning #1 (%)
A/F Learning #2 (%)
A/F Sensor #1 (AFR)
A/F Sensor #2 (AFR)
Engine Load (Calculated) (g/rev)
Engine Speed (rpm)
Exhaust VVT Advance Angle Left (degrees)
Exhaust VVT Advance Angle Right (degrees)
IAM (multiplier)
Learned Ignition Timing (degrees)
Mass Airflow (g/s)
Vehicle Speed (km/h)
User avatar
16bit ECU
Post by west_minist » Sun May 10, 2015 5:40 pm
A/F Learning #1 (%)
A/F Sensor #1 (AFR)
Engine Speed (rpm)
Feedback Knock Correction* (degrees)
Fine Learning Knock Correction* (degrees)
IAM* (raw ecu value)
Manifold Relative Pressure (Direct)* (psi relative)
Mass Airflow (g/s)
Primary Wastegate Duty Cycle (%)
Vehicle Speed (kph)
User avatar
32bit - Turbocharge (Legacy GT, Forester XT, WRX, STI)
Post by west_minist » Mon Aug 31, 2015 5:37 am
A/F Learning #1 (%)
A/F Sensor #1 (AFR)
Battery Voltage (V)
Engine Load (4-Byte)* (g/rev)
Engine Speed (rpm)
Feedback Knock Correction (1-byte)** (degrees)
Fine Learning Knock Correction (1-byte)** (degrees)
Manifold Relative Sea Level Pressure (Direct)
Mass Airflow (g/s)
Vehicle Speed (kph)
Innovate Wideband AFR (AFR Gasoline)
User avatar
CarBerry/GpN Logging
Post by west_minist » Sun Nov 08, 2015 8:30 am
A/F Learning #1 (%)
A/F Sensor #1 (AFR)
CL/OL Fueling* (status)
Closed Loop Fueling Target* (AFR)
Cylinder-1 Knock Count (Knock Events)
Cylinder-2 Knock Count (Knock Events)
Cylinder-3 Knock Count (Knock Events)
Cylinder-4 Knock Count (Knock Events)
Engine Speed (rpm)
Engine Load* (grev)
Fueling Final Base* (estimated AFR)
Manifold Absolute Pressure (Direct)* (psi absolute)
Mass Airflow (g/s)
Throttle Sensor Voltage (V)
Tip-in Throttle* (%)
Vehicle Speed (kph)
Volumetric Efficiency* (Load Multiplier)
User avatar
2015+ 3.6 Legacy/Outback
Post by west_minist » Thu Dec 29, 2016 5:20 pm
Ambient Air Temperature (°C)
Engine Speed (RPM)
Fuel Trim #1 - Long Term (%)
Fuel Trim #1 - Short Term (%)
Fuel Trim #2 - Long Term (%)
Fuel Trim #2 - Short Term (%)
Fuel/Air Commanded (AFR Gas)
Intake Manifold Pressure (psi)
Mass Airflow (g/s)
O2 Wideband Bank 1 Sensor 1 (AFR Gas)
O2 Wideband Bank 2 Sensor 1 (AFR Gas)
Throttle Opening (Commanded) (%)
Timing Advance (degrees)
User avatar
2015+ 3.6 Legacy/Outback EcuEdit Logger
Post by west_minist » Wed Feb 01, 2017 7:16 am
AirFuel Ratio S1 E1 (OBD) (AFR)
AirFuel Ratio S5 E1 (OBD) (AFR)
Ambient Air Temperature (OBD) (C)
Commanded AirFuel Ratio (OBD) (AFR)
Engine Oil Temperature (OBD) (C)
Engine coolant Temperature (C)
Engine Speed (OBD) (RPM)
Ignition Timing (OBD) (BTDC)
Intake Air Temperature (OBD) (C)
Long Term Fuel Trim B1 (OBD) (%)
Long Term Fuel Trim B2 (OBD) (%)
Mass Air Flow (OBD) (gs)
Manifold Absolute Pressure (OBD) (PSI)
Relative Accelerator Pedal Position (OBD) (%)
Short Term Fuel Trim B1 (OBD) (%)
Short Term Fuel Trim B2 (OBD) (%)
Throttle Actuator Control (OBD) (%)
Vehicle Speed (OBD) (KPH)
User avatar
Cobb Logging
Post by west_minist » Sat Feb 24, 2018 9:38 am
Accelerator Position
A/F Correction #1
A/F Learning #1
A/F Sensor #1 (AFR)
Battery Voltage (V)
Calculated Load
Engine Speed (rpm)
Gear Position (Gear)
Dynamic Advance Learning
Dynamic Advance Multiplier
Ignition Timing
Intake Temp (C)
Intake Temp Manifold
AVCS Exhaust Left
AVCS Exhaust Right
AVCS Intake Left
AVCS Intake Right
Mass Airflow (corrected)
Mass Airflow Voltage
Oil Temperature (C)
Wastegate Duty
Vehicle Speed (kph)
Throttle Position
