Oil Recommendations: Motul Oils
Engine Oil
Gear Oil
GEAR 300 75W-90
TYPE OF USE
Specially designed for racing vehicle gearboxes : speed way, rallye, raid…
All mechanical transmission, synchronised or not synchronised gearboxes, gearbox/differential, transfer gearboxes and hypoïd differentials without limited slip system operating under shocks, heavy loads and low revolution speed or moderate loads and high revolution speed.
PERFORMANCES
STANDARDS API GL4 and GL5 / MIL-L-2105D
100% synthetic extreme pressure lubricant for an efficient anti wear protection, a better resistance at high temperature and a longer life time.
0% shear loss : Unshearable oil film in extreme conditions
MOTYLGEAR 75W-90
TYPE OF USE
Specially recommended for gearboxes hard to shift and/or noisy gearboxes.
gearbox and hypoïd differentials without limited slip system operating under shocks, heavy loads and
PERFORMANCES
Extreme pressure lubricant for an efficient anti wear protection reinforced with synthetic base stocks for
a better resistance at high temperature and longer life time.
MULTI ATF
MULTI CVTF
Leave a Reply
Your email address will not be published. Required fields are marked *
nineteen − 15 =
